Question about Nintendo DS Console
Calibration of screen
I have calibrated my screen on several occasions, however it is still seems to be out. what else can i do?
Can You Tell Me How To Calibrate My Screen
Posted on Feb 16, 2008
New t880 tractors keep showing a calibration memory fault code. need helping figuring out what that means
On a new unit, the memory spaces for past calibrations are empty. The calibration memory gets filled during early operations and then the error should go away.
Mar 02, 2015 | Cars & Trucks
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found .... http://www.retrevo.com/pdf/23127ci168/76/Calibrating+the+Screen#q=Garmin+285WT
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
My gps touch screen does not seem to operate.I have tried resetting many many times.
try the calibration screen in the options menu and follow the directions...make sure you hold the screen over the X until it moves to the next position.
if that fails, you might need a digitizer...let me know and ill help you
further
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
bill
Standing Member of G.O.T.
Oct 03, 2010 | Magellan RoadMate 1412 Car GPS Receiver
P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
Unresponsive htc tytyn touch screen
i had the same problem, it turned out to be dust caught just under the plastic at the edge of the screen, a finger nail got it out or you could be fery careful and use a sharp flat knife. hope that helps,
Jul 28, 2008 | HTC TyTN Smartphone
Screen Calibration problem with SteetPilot c330
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Nov 30, 2007 | Garmin StreetPilot C330 GPS Receiver
Motorola a1200 screen calibration
If the screen calibration is way off then it seems that you can't even click on the crosshair during screen calibration. However, tapping on the crosshair does seem to adjust the calibration a little in the right direction each time, it's just not obvious that anything happened. So the trick is just to keep trying - gently and repeatedly tap the same spot on the crosshair for several seconds - eventually the screen will calibrate.
Oct 06, 2007 | Motorola Mobility A1200
Touch screen touchiness
Yes! I have an iWay 500C and all of a sudden, it started having serious calibration issues. I try to press a button on it and it thinks I'm pressing something about 2 inches below where I really am. I can't even get to the option to re-calibrate it when it does this, since the recalibration menu option is near the top of the display! I still have to experiment more, but the last time it did this, I think I had success by powering the unit on, waiting for it to finish getting a "fix" on the location (so the processor in it wasn't so busy), and then drawing a few big circles around the display with my finger. After that, it seemed to "snap into calibration" again.
Jul 27, 2007 | Lowrance Iway 500c GPS Receiver
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
