Washing Machines Logo
Posted on Jan 24, 2010
Intuitive Eco 701 ... error code 50. I'm sure it's to do with the fill solenoids. It is filling very slowly.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
421
Points
Yes. Whichever is filling slow. Hot or cold. It is a code for the fill valve. Just replaced the cold fill valve on my unit which seems to be the one that most commonly goes out. Easy repair. 2 screws and 1 Plug...If you unscrew the top by taking out two phillips screws in the back, you will find some paperwork about trouble codes, repairs etc...Right next to the fill valves.
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
3helpful
Code 49
it probably Needs a new cold water solenoid valve.
Fisher & Paykel intuitive eco - code 12 Water keeps running and I have to keep turning of the machine and water supply. Please help!
The solenoid on one of the fill valves, in the washer, is probably stuck open. Only fix is to have it replaced.
2answers
Error codes
We have an instruction manual but there are no codes.
Error code 131
Call the guy who replaced the motor/ module. Error 131 is serious. Not for home repair.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
