Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
Picture problem after changing highe presure lamp
Once i changed high pressure lamp after more like one year the colors on the screen vere going light blue to dark blue and picture is turning in to black and white with blue round on the screen
  • jjriese Apr 05, 2008
    I have already changed the pressure lamp once and now there is a blue haze creeping up from the bottom of the screen. What is causing this and how can it be fixed?
  • davidheidi Jan 10, 2009
    Has anyone ever been called back from LG. I have the same problem with my RU60SZ30. I called LG and they said the team will be back in touch with me. They have never called me yet. I fill that this is just a run around. You know they are aware of the problem, but I think they are just buying time and hoping the cosumers will just give up.
Asdasdas
Posted on Sep 02, 2011
Called them about my tv as well.. still waiting on a call back from the team
Posted on Jul 24, 2008
I just called LG about this issue. I was told there is a recall for this light engine & the recall team will call me in 14-21 business days. The rep I spoke with did not know whether labor is covered but it sounds like it will cover the entire repair. I spoke with Ruben at (800) 243-0000.
Posted on Jul 15, 2008
This is the light engine problem. i was able to get mine fixed through LG because its a known issue. this is not a bulb problem.
Posted on Jun 03, 2008
For age 52 whats my normal blood pressure
A normal Blood pressure for a 52 year-old male is less than 120/80 mmHg.
A Blood pressure reading between 120-139/80-89 is considered pre-hypertension, and greater than 140/90 Is hypertension (High Blood pressure).
Mar 17, 2017 | Health & Beauty
I have a Vivitek RP51HD41-A TV. The TV keeps turning off and on. The color and sound is fine. I have replaced the lamp and this has not fixed the problem.
If its a DLP it may have a color wheel which could be your problem (the colors will change etc)
Color wheels move at high speed and if slow down set will shut down.
The wheel if there will face the lamp. If often if failing will make a high pitched whine or a fan like sound.
May 29, 2012 | Vivitek V37655 56" DLP TV
I have a Samsung HLR5067WAX/XAA 56 inch, rear projection. Replaced lamp on it two years ago, was working fine. This morning a sudden thunderstorm blew in. When the power came back on, the cable picture...
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Apr 26, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Install new lamp, nothing comes on ,change back to old lamp still nothing
Hi,If the lamp didn't do the work it could be that the problem is with something else.If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Do you hear buzzing or high pitch sounds? If you do it could be a problem with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Make sure the door cover is properly shut other wise it wont lamp light up.
Apr 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
Picture getting dark regardless of settings and bright blue lighting on bottom of screen.  Set is 5 years old.
try replaced lamp Manufacturer LGE Part Number 6912V00006C Description LAMP, HIGH PRESSURE
Oct 01, 2009 | LG RU-60SZ30 60" Rear Projection...
Just changed the lamp in my samsung 4663w. lamp light blinks a while then all three blink. sound but no picture
hi, leaves only 3 options
1. color wheel not coming up to 6000 rpm`s
2. no ballast strike to lamp
3. lamp door safety switch in wrong position when door was re-attatched.
highly unlikely but not impossible u got a defective lamp, did your old lamp still come on? if so put it back in, if it lights up new lamp is bad, my money is on the color wheel if you installed lamp door correctly, gl, video-tek
Jun 04, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Computer Repairing
Computer Repairing
