Question about Dell A215 Computer Speakers
Speakers, Speakers, Speakers.
I just finished gutting out my old computer and and added my hard drive and all the old with the new, my computer is faster and well my speakers don't work...The speakers were given to me and they are DELL. everything is plugged in correctly but when I try to listen to music or watch a movie an error appears having to do with my sound device. The speakers worked well with the old computer, but not the new. I don't even have a icon in the lower right hand corner of my screen..Please any help would be grateful..Thanxx
  • Jesse Marquez Feb 14, 2008
    you know, Im guessing the old computer had a sound ard built in to the motherboard, as far as the new computer goes, I think it has one also, as I was putting the computer together and I thought of the soundcard, and well where you connect the speakers in, was almost identical so I wasn't worried about the difference...Should I take it to a computer tech. to see what is the matter. And if so can I get a price range on the cost? Thanxxx alot.
    Sergeant:
  • 239 Answers
Check in your control panel and open sound up and make sure you see a driver in under the audio tab, it should have a AC97 realtek or a sigmtel driver, If not find out what your old computers sound driver was and download it, You should be able to find the drivers you need at the computers manufactures web site, Now that should get your sound working after you install the proper sound driver, you stated you don't see the volume Icon in the lower right, My guess would be that is the problem. Thanks and take care
Posted on Feb 17, 2008
    Problem Solver:
  • 12 Answers
Before you do anything else, make sure you've plugged in to the proper slot (not the microphone, rear surround, or digital jacks).
If that's not the problem, there are several other possibilities, but most of them have nothing to do with the speakers you're using. To verify that the speakers work properly, plug them into a portable CD or MP3 player, slowly turn up the volume, and make sure they produce the expected sound. If they do not, it is possible that there is a short or other electrical problem that is causing the error you see (many modern sound cards attempt to auto-detect the type of speaker that is attached, and might be thrown off by very low--or infinite--resistance on the output).
Next, plug a pair of known-good headphones into the sound card output. If you get proper sound, go get yourself a new set of speakers. If not, the problem is probably with your sound card drivers (but could also be a hardware problem, which we will address first).
Assuming you have no success with the headphones, it's important at this point to determine whether you're using sound that's built in to the motherboard, or an add-on card (an external card will occupy one of your PCI slots on the motherboard--don't just look to see if the connectors are in a slot on the outside, since they could be in a non-PCI faceplate). If it's built-in, it's possible that it's not enabled in the BIOS. To verify this, reboot your computer. When it first starts, you can press DEL (or one of the function keys, depending on your BIOS) to enter the BIOS settings. Move around the menus looking for built-in peripheral options and verify that the sound system is enabled. Do not change anything else unless you are very sure of what you are doing. If you found the proper setting, save your settings and reboot.
If your card is an add-on, you could try turning off the computer and re-seating it (pull it out of its slot, then plug it back in). Make sure the metallic contacts on the connector are clean.
If you're still not getting any sound, go to your device manager (in Windows XP, right-click on My Computer, select Properties, choose the Hardware tab, and click the Device Manager button). Make sure no devices appear with a small exclamation point next to them; if one or more does, try reinstalling your sound drivers.
As a matter of fact, it shouldn't hurt to reinstall the sound drivers anyway. If, after this, you're still having problems, update your post with specific hardware and driver version information.
Posted on Feb 14, 2008
  • 22 Answers
Silly question do you have an onboard soundcard built in to the motherboard if not you should get a new sound card, does the earphones work ?
4 Suggested Answers
  • 883 Answers
SOURCE: Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
Posted on May 25, 2007
Benimur
  • 6966 Answers
SOURCE: Front and rear speakers do not work
My connection dropped for a second and lost you on the live session. Thereafter I keep on getting errors.
In any case, have you tried:
1. disabling the built-in sound in your CMOS/BIOS?
2. Verify that your Creative drivers are all installed correctly with no red or yellow marks in your Device Manager under Sound, video and game controllers;
3. Are all the connectors/plugs wired to the right jacks. Iknow the sub operates wirelessly but all others are still wired.
Post back pls how things are so we can figure other things out.
Good luck and kind regards.
Posted on Oct 23, 2007
SOURCE: no speaker sound
i have a dell computer my speakers want work
Posted on Jan 24, 2008
How to change the hard drive that contains the operational system in an Acer EasyStore H341 server?
Transfer an Operating System to a New Hard Drive
When replacing an old hard drive, a process known as cloning is the easiest and most thorough method for transferring data between the old and new hard drives.
A cloning utility takes a snapshot of your current hard drive and then re-creates that snapshot on your new hard drive.
The process clones everything, including the operating system, installed applications, settings and personal files.
Create a system restore disk so that you can return your system to its previous condition if an error occurs.
You can use a backup and restore utility provided with your operating system, or find one for free or for purchase on the Internet.
Many cloning utilities can also create system restore disks.
Shut down the computer and remove power.
Physically install the new hard drive.
Restore power and boot up the computer.
Ensure that your operating system recognizes that the new hard drive has been installed.
Pick the cloning utility that works best for you. (See Below for some options.)
http://www.easeus.com/disk-copy
http://www.clonezilla.org/
http://www.runtime.org/driveimage-xml.htm
All freeware
http://www.acronis.com/homecomputing/products/trueimage
http://www.symantec.com/norton/ghost
Purchase
Base your decision on your operating system and the cost and complexity of the utility.
Install and launch the cloning utility on your old hard drive.
Follow the instructions included with the cloning utility.
Keep the old hard drive as a backup, or reformat it for additional storage space.
Cloning a Notebook Hard Drive
Pick the cloning utility that best fits your needs. (See Above for some options.)
Base your decision on your operating system, the cost and complexity of the utility, and whether the utility can clone notebook hard drives using bootable media, such as CD-ROMs, DVD-ROMs or flash drives.
Keep the old drive as a backup in case the new hard drive fails.
or
Copy an OS to Another Hard Drive
Copying an OS or operating system to another hard drive can serve several functions.
Some simply want to move their current operating environment to a new PC, while others are replacing an old system hard drive with a newer one and want to avoid the hassle of updating and reinstalling.
The process of copying your operating system to another hard drive is a very easy one, in fact, and can be accomplished by anyone with nothing more than some software and some time.
Install Acronis True Image and launch it from its installation icon.
A link is provided below for the Acronis free 15-day trial.
http://www.acronis.com/homecomputing/download/trueimage/
http://www.feyrer.de/g4u/
Support free software or g4u WILL die!
http://www.macrium.com/reflectfree.asp
Macrium has a free also pay options
Click the "Utilities" button from the left menu bar.
Click the "Clone Disk" button from the right pane of the main program window.
This will cause a dialog box to appear.
Click the "Next" button on the bottom-right corner of the dialog box.
Select the disk with the operating system you wish to copy from the drive list and click the "Next" button.
This will begin an examination of your hard disk that will finish in a few minutes.
Select the destination disk from the hard drive list and click the "Next" button.
Choose the "As-is" option for how you would like to handle your partitions.
This option merely lets you decide whether to keep all partitions on the drive or copy just the data onto one blank partition on the new drive.
Click the "Finish" button, and Acronis will prompt you that your system needs to be restarted to begin the cloning process.
The restart will happen automatically when you click the "Finish" button.
Allow the computer to restart, and Acronis will launch prior to the operating system and begin the cloning procedure.
This process may take several minutes to several hours, depending on the size of the operating system and whether there are any installed applications.
Restart you computer once again after Acronis has completed the cloning procedure.
The software will notify you when the cloning has finished.
Boot into your operating system and use your new operating system installation as normal. You may now remove your old operating system drive or format it as you desire.
Hope this helps.
Nov 24, 2012 | Computers & Internet
WRITE PROTECT
There is possibly a write protect switch in the hard drive case, I will confirm this and get back to you.
Oct 30, 2008 | Western Digital External USB 2.0 80 GB...
Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
May 23, 2012 | HP Omni Computers & Internet
OptiPlex GX150 series. Diskette Drive 1 Seek Failure. Primary Hard drive 1 Not found. Secondary Hard drive 1 not found.
Sounds like a hard drive failure. It is fairly easy to purchase a new hard drive and put it in, but then you must have the software to re-install everything. If you are a bit concerned about doing these things, take your PC to a PC Repair shop and they will install a new hard drive and put a new operating system on it. Depending on how old the Desktop is, you may want to buy a new PC as the old motherboard may fail on you in the next 6-months to a year. Check your gut on this.
Oct 29, 2010 | Dell OptiPlex GX110 PC Desktop
WHAT COMPUTER PART CAN I USE IN MY NEW COMPUTER?
If you are talking about a desktop, you may be able to add a USB card to it, which will give you USB functionality. But, if your computer is *this* old, you might be better off getting a new one anyways just for the huge performance increase. You are always able to add more RAM to it, upgrade hard drive, etc. Adding memory is the single most upgrade that helps a computer be faster.
Considering that your old computer doesn't have USB ports, there likely is very little that you will be able to use on the new one. Several leaps in technology have occured.
But, to answer your question, you can likely move the hard drive from old computer, as well as the optical drives (CD/DVD). If your graphics card is not part of the motherboard, that can be brought over as well. Add the keyboard and mouse, and that will be about it.
Jun 16, 2010 | HP Computers & Internet
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Added a new hard drive to my desktop compaq presario sr1620nx and trying to install my operating system and its says no operating system found or corrupt partition and when i hit r to recover its brings me...
You can't transfer the operating system. You have to reinstall it on the new hard drive. Most of the time the disks that come with a computer are just restore disks. Without the restore partition that comes on the hard drive that came with the computer, those disks are usually useless. Or if you want, you can keep both hard drives, and just setup the jumper settings on the hard drives so that the old hard drive is the primary, and the new one is the secondary. Then you will still have the operating system and you will use the new hard drive for storage.
Apr 21, 2009 | HP Compaq Presario SR1620NX...
320 WD external hard drive
Could you be more specific? What do you mean "when I plug it into my computer?" Whay did you buy one..was there a problem with your existing one? Did you replace your old one or are you adding this new one to the other. Did you use the software that came with the new WD? Many details that you have ommited.
Justsayes
Nov 24, 2008 | Western Digital External USB 2.0 80 GB...
E-MACHINE T5248
how old is the machine???
what kind of hard drive??? IDE or SATA
the newer machine do not need hard drive configuration. but not the old one.
configure the old hard drive to "master" and the new hard drive to "Slave".
go into BOIS and make sure both hard drives are being detected by the machine.
Oct 19, 2008 | Computers & Internet
Dell A215 Computer Speakers Logo
158 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
