Question about Motorola Mobility RAZR V3
DISPLAY GOING ON AND OFF
I HAVE A NEW (2 WEEKS OLD) RAZOR. I HAD IT ON CHARGE AND WHEN UNPLUGED IT AND OPENED IT THE SCREEN WAS GOING ON AND OFF AND YOU HAD TO MOVE THE FLIPED UP PART TO MAKE IT STAY ON.
I TURNED IT OFF TO SEE IF IT WOULD CLEAR UP BUT DIDNT.
    Brigadier General:
  • 7,752 Answers
Take the phone back from where you bought it , the phone's firmware needs to be reflash but if the phone is still under warranty have it exchanged.
Posted on Feb 14, 2008
Why does my monitor die (it goes black) when I remove the adapter even if the battery is 100% fully charged?
Try going into your control panel, and resetting the options for your display.
Mine works this way...click Start button lower left corner of screen.
Type the word display in the search box. that will open a window that will allow you to decide when the display can be turned off.
If that doesnt get you to display settings try pushing Start button,Find the Control Panel button and clck it.Find Mobile PC, or Power Options. If you find Mobile PC click it, then find Power Options.on the left side is a caption that allows you to dicide when to turn off the display. Hope it helps
Jan 25, 2013 | Lenovo G480 218422U Dark Brown 3rd...
I am having a problem with one of my Printers, it is a brand new printer, Model Canon Image CLASS MF 3222. It was running alright for about 2 weeks, now it displays on Printer LCD ( System Error 225 ).
If you open the scanner cover you should find that the scanner lamp is not lighting. as the machine is 2 weeks old it will be covered by the warranty. Telephone canon service to book at service call and it should be repaired free of charge.
May 23, 2011 | Office Equipment & Supplies
Philishave8890 when the razor states fully
It sounds like the battery pack needs replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Sep 26, 2010 | Philips Health & Beauty
Electric razor won't charge
I've had two different charging issues with my wet-dry electrics over the years. The first is the same one as here: The battery croaks and you need to replace it. I take the old one apart, save the screen and its housing and put the battery in the recycle bin. Then, I go on-line and simply order a new one. Unless you have a really expensive razor, replacement parts and shipping costs aren't worth the trouble.
The second is that because I use mine in the shower, the contact pins & sockets on the charger & razor develop a layer of lime or calcium scale overtime. This thin layer of scale insulates the contacts from each other and prevents the razor from charging. At first I tried high-end "Cramolin DeOxit" but with no success. Then I poured a small amount CLR on the pins and sockets and scrubbed them with an old toothbrush. After rinsing with some clean water and drying with a paper towel and a few blasts of air, it charged perfectly! So, check your charge status light first to be sure you have a good pin/socket connection before leaping for a new battery.
Dec 07, 2009 | Panasonic ES7058
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
V3 razor screen is locked
describe ur problem briefly for help!!!!
May 16, 2008 | Motorola Mobility RAZR V3
Charge complete but phone/display does not work
it is technical problem pleas go to sarvice center and replace u r handset cause it is in warrenty dont try to open it, or change with new battery
Aug 20, 2007 | LG VX3100
My cell phone wont display anything
I had the same problem with an old razor. I ended up having to discard the phone and got a v557. But these were the steps I took: 1. Took out the battery for about 5 min. I called tech support and they said that most problems are due to software errors and can be fixed by taking out the battery then reinserting it. 2. I reinserted the battery and booted it up. The keyboard lit up and the welcome screen played. After that, it shut off. 3. I charged the battery completely and tried to reboot. Same thing happened. If none of these work, it's probably the battery's fault or the phone's fault. Either way, you should get a new phone or contact a professional fixman. Hope this helps.
Jul 27, 2007 | Motorola Mobility V551
No display screen Razor
I lost my display on 30th april 2007 without a hint. Have been using the phone for nearly 1 1/2 years without any problem. The battery seems to be not so strong, shall try with the battery cleaning etc. Is this a standard problem with the MOTOROLLA V3? Cheers Bevanie
Mar 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
