Question about Dell W2600 26 in. LCD Television
Wow;; I have this TV for like 2yrs already...a month ago I started to have the same problem no power on after I turned off. what I used to do was unplugged it and try to turn it on for several time it will work but as soon as I turned that @#$% off I had the same problem....now it's not turning at all I called Dell and they told they will replace it.
    Genius:
  • Dell Master
  • 1,689 Answers
It is very common that the power supply, and or the backplane lamps and lamp ballast supplies fail in LCD sets.
Jerry G.
Posted on May 15, 2008
55" led ,replaced the power supply a couple months ago, tv has been working properly until a week ago, now seems as though the power supply is going out again.could there be something causing this.
Hello Geoff Bowen,
Industry standard is now pretty cheesy capacitors...
(the reason not to feel persecuted until number three fails!!
but yes... if you have your set in the sun-light or poorly ventilated... any increased heat will cause the caps to fail MORE QUICKLY.
(always use a wrist band on any board you care about)
But by the time that happens you will have already figured out
to send your old boards for repair... or better...
Started your own cottage industry
(these things are popping like POP-CORN).
Even Amazon has cap "kits" and replacement boards.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 23, 2016 | Televison & Video
LG 32 Flat Screen Tv Won't Turn On.
What i would do if this was happening to me, i would turn it on by the buttons on the tv and if that still doesn't help it turn on then use the tv remote. I bet you have already tried both and haven't worked. How long have you had the tv for?
Jul 11, 2015 | LG 32LG30 32 in. LCD HDTV
Onan 6500 less than 2yrs old and used once. Try
Your air filter may be stuck with dirt or moist. Try to clean or change it.
In all cases the problem is in the air duct, if it runs well without air filter.
Jul 17, 2010 | Watts Onan Portable Generator - 5000 ,...
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
With TV OFF Press and hold vol- and ch- at same time untill tv comes back on release you should now be in Service Menu.
Feb 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power turns off right away
Its correct, Sony is no more selling plasma and I think many companies has already shut plasma production and CRT TV as well.
All TV manufacturers are busy in LCD TVs.
Jan 17, 2009 | Sony WEGA KE-50XS910 50 in. HDTV-Ready...
Dell W2600 26 in. LCD Television Logo
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
