Question about Brother LS-2125 Mechanical Sewing Machine
Brother walking foot help, please
I need help, finally put the walking foot on the machine, and did a quilting project--actually turned out well, but last night, when I wanted to changed back to the regular pressure foot, when I removed the screw and lifted the part off the machine, a small piece was seperate. I can't figure out where it came from, since the side screws from the walking foot are still in place, and I can not find anywhere to reattach. I looked in the original material from Brother, but only see a picture of the walking foot--and can't find on the internet any "part" list or diagram for this food. Can anyone hel?p
  • 1 more comment
  • macnikoli Feb 14, 2008
    oops, wrong machine listed, I have a Brother computerized machine, walking foot problem,
  • macnikoli Feb 15, 2008
    thanks, model CS100, I can find the picture and directions for walking foot--but not the actual parts within the foot--that is what "came out", can you help?
  • Anonymous Mar 28, 2014
    Can't unscrew pressor foot screw
    Genius:
  • 3,422 Answers
Here you go download the manual from HERE.
If you have any other problem please feel free to ask.
Goodluck..
Posted on Feb 14, 2008
  • Priya darshan Feb 15, 2008
    Please go HERE you will find the diagram and of the sew machine of other brand but it is approximately same as yours.You wiil see the numbers on the diagram which ever you feel the part is check it on the above table with same no.and you can buy that part.
    here is the main support no. 800-276-7746
    You can contact them and ask about the part and also ask them from where to get it if you don't get your part from my suggested link.
    Goodluck,
    Please don't forget to rate me as fixya..
    Genius:
  • 1,665 Answers
Do I need a walking foot to stitch in the ditch using Viking freesia 415?
A walking foot would be helpful especially for quilting where there are multiple layers of fabric. The walking foot actually moves the upper layer in conjunction with the lower fabric helping to prevent wrinkles in the stitching.
For other projects, there may be other feet that could work. Your sewing machine may have other accessories, like this foot for Berninas Blindstitch foot 5
stitch in ditch Google Search
FWIW, it is very difficult to actually stitch "in the ditch" as any slight deviation will show. Usually, it is better to stitch just a bit to one side or the other.
Dec 10, 2017 | Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
How do attach the walking foot Brother
Jun 26, 2017 | Sewing Machines
Brother cs 6000i squeaking
By any chance were you using your walking foot when it was squeaking? I had the same issue and realized it didn't squeak unless I was using the walking foot, it was actually the walking foot that was squeaking :D I can live with that!
Sep 02, 2009 | Brother CS-6000
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Jul 25, 2008 | Brother CS6000i Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
328 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
