Question about Fuji FinePix E510 Digital Camera
Flash problems Hi i cant get the flash working on the E 510. tried to change the settings, but nothings seems to work. Can there be a short in the wire system or can the bulb be burnt out?
    President:
  • 423 Answers
Yes and yes. If you've popped it up and it won't fire, it looks like you're in for a repair, hopefully under warranty.
Posted on Feb 17, 2008
Vivitar vivicam 8010 cant get flash to work
Hi There is a switch on the end of the camera if you move it to the little mountain logo the flash should work fine (obviously press the flash on button ). if the flash is too bright change the ev setting to -1 and give it a go . if it's still a little bright change the ev setting lower until you happy.
Jan 20, 2009 | Sony HVL-F36AM TTL Flash
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
FLash light
Try removing battery and sim.
This may help if it resets.
Jun 20, 2008 | Nokia 6111 Cellular Phone
Flash not working
better take to sony dealers resolving flash problem because there might be some connectivity lost inside the chip deign of camera
Jun 14, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Sony Cybershot DSC-H7 - can not change flash settings
for anyone who wants to know how i solved my problem with the flash saying it cannot be changed...
If you go into the camera settings; look under rec mode. It might be in "burst" mode. Flash will only work while in "normal" mode.
Mar 16, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Flash is not working ??????????????
This camera has four flash modes and each time you press the button the mode changes. As you press the button you should see the indictor in the upper left side of the screen.
1. In automatic flash, the camera will decide if you need flash or not. This mode does not have any indicator on the screen
2. Forced flash, this will cause the flash to be constantly on. The indicator looks (kind of) like a lightning bolt.
3. Slow Syncro, this mode slightly delays the flash and is used to lighten up the background more the foreground. The indicator looks like the lightning bolt with SL next to it.
4. No flash, this will turn off the flash. The indicator looks like a lightning bolt enclosed by a circle with a diagonal line through the lightning bolt. (similar to a no parking sign).
If you don’t see the indictor changing on the screen the switch behind the button is malfunctioning.
Nov 26, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Flashing auto check and test/charge
This means that your batteries are low on power.
Oct 07, 2007 | Olympus FL-50 TTL Flash
Fuji FinePix E510 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
