Question about Refrigerators
Water leaking from fridge
Twice a day I am finding a puddle of water on the floor by the right hand bottom corner of the fridge. I am assuming it leaks when it cycles. I attempted to clean out the drain pan and do not have access to it if there is one. The owner's manual is worthless. Help
  • 3 more comments
  • mamamick Feb 14, 2008
    Samsung RS2544SL
    There is no water at the bottom of either the fridge nor the freezer
  • Anonymous Sep 10, 2008
    There is foul smell coming from the back of the refigerator when plugged in, and water is leaking. I have no ideal where to find the water pan.
  • robert samples May 11, 2010
    ok is there any water in the bottom of the fridge its self if not see if there is any in the bottom of the freezer
    the brand and model would help
    President:
  • 1,314 Answers
Ok look in the back the drain pan should be there then check your door seals for leaks
Posted on Feb 14, 2008
  • robert samples Feb 14, 2008
    do you have an auto ice maker if so hows your ice production check there for leaks and if production is bad check the fill tube to see if its frozen
  • 22 Answers
Hello I had a problem close to this, at the back of the fridge on the bottom you should find the motor ,sitting on top of the motor there should be a small cream plastic catch tray if you dont have one this may be the problem as the motor evaporates the excess water, Hope this helped. djdizzys
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
LARGE WATER LEAK ON FLOOR
the reason is probably that the drain hole in the freezer (i assume this is a frost-free type) is blocked. take off the rear panel of the freezer and you will probably see a block of ice at the bottom. melt off with a hairdryer and free the drain with hot water making sure that water flows freely away
May 06, 2007 | Zanussi ZEBF250W Bottom Freezer...
Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Refrigerators Logo
411 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
