Question about GE Spacemaker JVM1640SJ Microwave Oven
The Keypad stopped working
I have JVM1190AY003 and the keypad stopped working.  Over the holidays, a few buttons stopped working, then on monday the keypad stopped working all together.  I think the steam from cooking started the problem.  Could that be?  The display is working it keep scrolling "press start" and the interior light works also.  What could be the problem?  I called GE and they said they didn't know what was wrong over the phone, but then they Fed Ex me a package, it was a replacement smart board and thermo sense.  What do I do now?
  • JayBail Feb 25, 2008
    Okay, I know I am running the risk of sounding really clueless now but I am going to continue anyway, what should I do now?  Should I try to replace the keypad?  Should I do it myself?
    I was just going to skip the headache of the whole thing and just purchase a totally new microwave.  Is it worth it to repair?
  • Anonymous Mar 31, 2014
    turns-on for a second when start is pressed and then stops. Digital display, keypad, exhaust fan, external light all work ok.
  • GE Master
  • 9,098 Answers
I suspect you atually have a bad keypad, but apparently GE decided to send you some free gifts? Wow. Sell them on eBay if they're not needed. *grin*
Replacing the keypad is usually a pretty easy job for a DIYer.
In many cases, it may be caused by steam or grease, but it may also just be a failure over time. I always recommend that you use the vent fan whenever you're cooking on the stove top. That helps keep steam, grease and heat away from the microwave controls.
We have *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting. You can use it for testing your keypad.
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 15, 2008
The top quick access buttons stopped working 2 days ago. The bottom buttons still work but, we can't punch in a custom time. The only thing that will work is the 1 for 1 minute 2 for 2 minute...etc.
One of two things is happening, either you have broken connections in the membrane switches of the keypad and should replace the keypad(which is most likely) or your main control board has failed in a way that it can no longer read signals sent by the keypad.
Aug 04, 2013 | Microwave Ovens
My LG Microwave is not working. The STOP/CLEAR button does not work
see the next steps: USE THE commons sense . God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 01, 2012 | Microwave Ovens
The oven (10+ years old GE True Temp double wall oven) beeps and displays an F7 error message. We can temporarily stop it by pushing the Clear button, but it starts again in a few seconds. We don't know...
I'm a GE tech, the F7 means there is either a stuck button on the keypad or relay on the board behind the keypad. Shut off the breaker. Remove the 3 screws under the keypad and lift the panel a bit to remove it. Lay it face down on the top rack and disconnect the ribbon cable. Turn power back on and if f7 goes away the problem is in the keypad. If f76 returns it's in the control. We typically replace both together because usually if you replace 1 it will come back later then be the other part.
Mar 26, 2011 | Microwave Ovens
I cannot press start and stop button i think sensor is not working i can press rest 1234567 button n not 890 n start n stop button
Normally, it suggests the keypad is faulty. The fact that you have part function indicates the board is functioning. Replace keypad.
May 28, 2010 | Sanyo Microwave Ovens
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
KEYPAD STICKING AND STOPS WORKING
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Dec 31, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
Feb 17, 2008 | Emerson Black Microwave Oven
Kenmore microwave
The Keypad is a Circuit.Each of the Function Buttons is a switch. The same "Touch" Techinology as is used of your TV Remote Control Pad or your Telephone. It would appear that your Keypad Circuit is Open, not allowing touch commands to reach the Control Board.The Keypad will have to be replaced. Best done by a Professional. I have seen "Rare" cases of a defective Door Switch causing such symptoms.
Jan 26, 2008 | Microwave Ovens
Frigidaire FMV145DB2 over the range microwave
I'd say you have a bad or contaminated keypad. It's extremely unlikely that your control panel is bad. Sadly, there are some shops out there that just replace the whole assembly and are not able to troubleshoot and repair them like we do. Just in case, I would suggest you try to reset it by unplugging it for a few mintues then plugging it back in. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, by spraying of cleaners, by storing the microwave in an unheated garage or shed, or by infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If a reset didn't fix it, then you probably have a bad keypad. Replacing the keypad (if it's available as a separate part) is not too hard for a service tech or handy person. Frigidaire is at 1-800-374-4432 Monday - Friday 9:00 am - 5:30 pm EST. I'd call to see if it's available. Concerning the turntable motor, $139 is an insane price! Sounds like your repair person didn't want to work on it and was trying to get rid of you! Sad... Try Appliacne Parts Pros at http://tinyurl.com/gv383 Reply back if you need more help.
Dec 12, 2006 | Frigidaire FMV145K Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
378 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
