Question about Foxconn 865A01-PE-6EKRS Motherboard
Pc won't power up
I replaced the power supply on my gateway 310x pc. a small green light is on on the motherboard but nothing else happens, not even the fan on the new power supply. help!
  • 20 Answers
Check whthr the SMPS has been connected properly or nt.. check the power chord n thn restart d PC if thn also it fails thn thr might be problm with ur POWER box..SMPS
Posted on Feb 14, 2008
    Problem Solver:
  • 23 Answers
Dear Buddy117,
What i have understand that u r Motherboard getting the power supply but i want to know that is u r SMPS power supply fan rotating or not if no then u have to change the SMPS if it is ratating then u have check the power switch in u CPU cabinate is that power switch wire properly connected to the motherboard if it is connected then check wether it is connected in right place or not i hope this information will going to help you.
Regards,
Bittu_8
Where is located the sound card for gateway 310 x h computer
Go to http://support.gateway.com/s/PC/310_Series/2800350/2800350rv.shtml
The sound card is part of the motherboard - the three small jacks (pink, yellow (green?) and blue) just below the USB/network ports are for the sound card functions. Pink = Microphone, Yellow (Green) = audio out, Blue = audio in.
There is also an audio out in the front of the computer for headphone output.
Dec 24, 2010 | Gateway 310X PC Desktop
Gateway 500s power box when hitting test button powers both fans, but no power to hardrive, dvd, or monitor. I have replaced power supply, motherboard, and harddrive, I have nothing, but green power button...
Does the fan on the power supply run? As you say the power on switch lights up and so does the motherboard, means that the power supply is working. Monitor gets power from the socket on the power supply. Try plugging it in the wall socket. Try to unplug the main power cord from power supply to the motherboard. The one that has a broad plug at the motherboard end. Replug it and they power on the PC.
Sep 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Gateway 507gr wont power on but looks like ps unit is good
Make sure you are plugging in your P.S. to Motherboard properly. This can happen if you are off by one pin on a 20 pin Supply on a 24 pin Motherboard. If you never opened the case and it just started happening, maybe one of your cards came out of its slot or your CPU Fan is not running.
Nov 06, 2009 | Gateway 507GR PC Desktop
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
Gateway 3200S will not power up.
i have a big feeling its the mother board
Jun 04, 2009 | Computers & Internet
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
My gateway is not turning on!?
The most likely possibility is you need to replace the power supply. If you have a power supply tester you can check it. If not you may want to borrow or purchase a new one. They, for the most part, are not that expensive. I hope this helps. Joe
Nov 25, 2008 | Gateway GT4016 Desktop PC
Harddrive indicator light doesn't come on my gateway 310x
try another set of key board and monitor if this does not work u might have a bad processor I look forward to helping u Shaun
Nov 15, 2008 | Gateway 310X PC Desktop
GX7022E Gateway computer no power up
*check for the powercord wheather it is good or not
*check the power outlet
*in bios see wheather hardware settings are correct
*open the system then see power switches are connected properly or wheather there is an any loose connection
*check the cpu fan is working properly or cpu is heating and see cpu is placed properly
*keyboard is connected properly
*check jumper settings are proper
Jun 24, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Foxconn 865A01-PE-6EKRS Motherboard Logo
149 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
