Question about Samsung AH5900092W Remote Control
Remote blocked my samsung remote is blocked except the volume control, any tips to unblock, thanks
  • 1 more comment
  • guru nagaraj Feb 19, 2008
    my remote is also locked and pretty much nothing else works other than voume button
  • steve78_uk Feb 24, 2008
    I''ve got exactly the same problem :( only the volume buttons and mute work
  • jcbflanders Jan 11, 2009
    only volume and mute works on tv. but the on off and the channel control switch's the samsung vcr
Managed to fix mine now. Remove the batteries and hold one or more buttons on the remote down for a few minutes. This will drain the controller and reset it. When you put the batteries back in it should work again :D
Posted on Feb 24, 2008
Excellent that worked perfect
Posted on Aug 29, 2008
Thank you very much.
It worked like a miracle.
Posted on Jul 13, 2008
Brillaint.... it worked!!! Thank you Steve_78!!
Posted on Jun 28, 2008
Thanks a lot.
The solutionprovided above works like a charm.
Posted on May 13, 2008
Many thanks.
Your fix worked. We were just about to give up and buy anew remote or TV
Posted on Mar 21, 2008
I have the same problem can anyone help
Posted on Feb 19, 2008
How do I override the password on a Toshiba cx32f60 tv? All channels above 13 are blocked. I want to unblock all of them. The remote is a Toshiba ct-9809.
Hello
Disconnect the AC power for at least one minute to reset the clock running inside the circuit.
Adjust Volume to Minimum using the Volume Down button on the front panel of the TV.
Press and Hold the Volume Down button on the front panel of the TV and the "Zero" button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password. OK.
Nov 04, 2011 | Toshiba CX32F60 32" TV
Tip
PIN and PUK
I have seen a lot of posts here about unblocking a PIN and PUK code.
Hopefully this tip will help Fixya users who experience this problem, at one point in time.
First of all, the PIN and PUK codes are not phone codes, they are SIM card codes.
The PIN (Personal Identification Number) is a code that restricts access to your phone, through the SIM card.
If you insert a SIM card that has no PIN restriction, you will not be asked for the PIN code.
When you enter the wrong PIN more than five times, it will get blocked, and ask you for the PUK code.
The PUK (Personal Unblocking Code) is used to unblock a blocked PIN.
If your PIN is blocked, use your PUK to unblock it.
Tip:
The PIN and PUK being SIM card codes, no one else can provide them to you, not even your phone manufacturer, except your network service provider.
If you dont have your PIN and PUK, call your network service provider customer care and they will provide you with both the PIN and PUK codes, for free.
I hope this tip will help you in case your PIN gets blocked.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Cell Phones
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
How do i unblock the channels, no remote
Try this:
On Remote Press Channel Up And Volume Down At The Same Time For 5 Seconds. Then Enter 0000 As Your New Password.
Oct 24, 2009 | Televison & Video
The down volume on my remote is not working
You can quickly test the remote in question with a digital camera... please vist my Tips & Tricks so see how.
Oct 20, 2009 | Samsung TV Remote Control
After working fine, remote wont work properly. sometimes works, but not always; volume control suddenly does not work
Try opening your remote and clean the side of the pcb that the rubber buttons rest on with a q tip containing acetone or methylated spirit.
Aug 17, 2009 | Samsung TV Remote Control
Programing remote control
Since you obtained a used TV, there probably wasn't an owner's manual with it. Here is the site where you can read and/or print the manual. http://www.sanyoservice.com/pdf/images/DS27510(OM)_excluded_French.pdf
On page 6 in the Quick Tips column, the second tip states: If the remote control does not work: Press TV key (see item 1).
Good luck resolving your problem.
Jan 29, 2009 | Sanyo DS27510 27" TV
Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Remote code
hi i have a samsung ws-28a116d tv the remote has stopped working with the exception of the volume and mute keys can anyone help????? post to kane715@hotmail.com
thanks
Oct 23, 2008 | Televison & Video
Samsung AH5900092W Remote Control Logo
469 people viewed this question
Henry  Thomas
Henry Thomas
