Rear Wheel Bearing
REMOVAL AND INSTALLATION
1. Remove the wheel knuckle.
Wheel Knuckle
CAUTION: Do not loosen the axle wheel hub retainer until the wheel and tire are removed from the vehicle. Wheel bearing damage will occur if the wheel bearing is unloaded with the weight of the vehicle applied.
1. Remove the wheel and tire assembly.
NOTE: Have an assistant press the brake pedal to keep the axle from turning.
2. Remove the nut and washer and discard the nut.
3. Remove the parking brake shoes.
CAUTION: Do not damage the boot while separating the toe link from the knuckle.
4. Remove the nut and bolt and separate the toe link from the wheel knuckle and discard the nut.
CAUTION: Do not damage the boot while separating the ball joint from the knuckle.
5. Remove the nut and bolt and separate the upper ball joint from the wheel knuckle and discard the nut.
CAUTION: Do not use a hammer to separate the outboard CV joint from the hub. Damage to the threads and internal CV joint components may result.
6. Using the special tool, press the outboard CV joint until it is loose from the hub.
7. Remove the nut and bolt and the wheel knuckle, hub and bearing as an assembly and discard the nut.
(Return to)
Rear Wheel Bearing
2. Remove the three bolts.
CAUTION: Make sure that the press adapter outside diameter is slightly smaller than the hub outside diameter or damage to the knuckle will result.
3. Using a suitable press, remove the hub from the bearing and discard the hub.
NOTE: The retainer ring is tapered and must be installed flat side down.
4. Remove and Discard the retainer ring.
5. Using a suitable press, remove the bearing from the wheel knuckle and discard the bearing.
CAUTION: The hub and bearing cannot be reused after disassembly.
To install, reverse the removal procedure.
SOURCE: The wheel bearing on the front right side of 2002 Ford Explorer
I removed the whole knuckle and placed it on support then used a sledge hammer to knock the old bearing out. It is a simple job but would be easier with a bearing hub puller that I don't think anyone has.
SOURCE: 2002 ford explorer front wheel bearing assembly
remove hub ,take retaining circlip out and knock it out with a big big hammer supporting it on an old wheel rim and a tree trunk.this job is easy to do but unless you have the right tools entrust it to a garage who will have a nice press .
SOURCE: replace rear wheel bearing 2002 ford explorer 4x4
you must remove brakes, then remove axle nut, then remove upper control arm and finally tie rod stabilizer, remove axle from car then bearing can be accessed. this is a difficult job that requires special tools so be careful
there is not 3 bolts that hold wheel bearing in.
