Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer doesn't dry
Could the accomulation of lent on the trap could cause ireparable damage to the dryer?
  • 5,911 Answers
YES, most defintely. This typically causes the dryer to overheat and eventually blows the thermal cut-out or heating element.
SYMPTOMS:
Dryer runs, but does not heat - possible bad heating element or thermal cut-out.
Dryer does not run at all - possible bad door switch, blown thermal fuse, timer or drive motor.
Does your dryer exhibit any of these symptoms? Please post back and let me know.
Posted on Feb 14, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 14, 2008
    Keep in mind, lint traps are not perfect. They do not catch ALL the lint. SOME lint can get pulled past the trap and into the interior of your dryer where it accumulates on the heating element or gets caught in the blower fan assembly. If caught in the blower fan, the blower does not blow air a fast as it should. If accumulated on the heating element, it could catch fire. If you're in the habit of not cleaning the lint trap, you're allowing lint to sit and get pulled into dryer unnecessarily. That's why it is important to clean the lint trap after each use.
My Kenmore 110.62212101 Dryer won't dry my clothes. My heater element does not come on at all and my lent trap is clean.
There may be a blown fuse, but most likely the heater element is burned out. They're not very expensive and pretty easy to replace.
Oct 23, 2014 | Dryers
My kenmore dryer wont click on, it will light up and click but nothing happen's I cleaned out the lent trap and the lent funnel and it still wont click on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Dryers
Dryer heats ,tumbles, but clothes still wet.cleaned all lent traps.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 23, 2010 | Kenmore Elite HE4 Electric Dryer
My maytag 3000 series dryer is not even a year old untill 2 more days, it does not dry my clothes no matter what setting I have it on the lent trap gets cleaned about 2 or 3 times during each cycle,yet it...
oooow,,,temper temper,,,,take a deep breath,,,
i think the temp censor has stoped working thats why its not getting very hot its that or the heating coil/s are broken,,also check the air vents at the back are not blocked up if so its not getting any air to it,,,
then go out and find a big stick,,,and batter it with the stick,,,
this realy wont help fix it,,but it will make you feel soooo much better?
Jul 12, 2010 | Maytag Dryers
Dryer shuts down after 5mins and also has a random
I think the vent is pluged up or bent so that the lent is trapped in the hose. its getting too hot. don't use it anymore till you get it cleaned and check for lent build up in side. can cause fire.
Jan 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Sep 10, 2009 | Dryers
Whirlpool dryer model wed5300sq0
My dryer heats but it takes more then 3 x to get the clothes completely dried. Why does it take triple the time to dry my clothes now.
Jun 15, 2008 | Whirlpool LER5636P Electric Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
102 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
