Back to:
Tags:
Barebone Systems
Generic problem for all Barebone Systems
Fitting memory stick in 2400 printer
posted by lewismonti on Feb 14, 2008
I have hp psc2400 photosmart series all in one and am unable to insert sony memory stick PRo Duo 2GB magic gate
into slot to transfer photos.I do not know which is the correct slot as none seem to accept the stick.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 14, 2008
FixYa! (100)
map9966
Rank:Guru Guru
Rating: 89%, 1288 votes
Your Magic gate is half size. You need an adapter that you put your magic card into which will bring it up to the standard SD size for your printer. You can find these at place's like Best Buy. Bring your magic card with you & make sure it fits before you leave the store. Click this link & you'll get the idea of what you need.
http://www.geeks.com/details.asp?InvtId=SDMSPDU-2048-A10M&cm_mmc=googleproducts-_-FlashMemory/CardReaders-_-MemoryStickPro/ProDuoCards-_-SDMSPDU-2048-A10M&ci_src=14110944&ci_sku=SDMSPDU-2048-A10M
Rating Locked! (?) lewismonti has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on fitting memory stick in 2400 printer:
I don't want to Accept this solution
Can you Help with these Barebone Systems problems?
Jetway (MINIQ 860TWIN) Barebone
hello need help i have intel 2.66 + asus p5gcmx with 8600...
Barebone Systems
I am trying to hook up an PIII-3754LMR - mobo. I could...
Barebone Systems
Dear, Sir/ Madam I just bought Singer Ce200 sewing &...
Barebone Systems
Hi I have a uniwell 875 machine and have lost the manual...
ASUS Pundit-R Barebone
Hi, I have problems with Pundit-R and Powercolor HD2400...
Loading problems.
Repair Service
Find Barebone System Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
