Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover steam-vac model #F7458-900 "All-Terrain"
Upper tank/water and det.flows out when unit is turned on-without pressing trigger
  • Anonymous Mar 31, 2014
    Pressing trigger when on rinse mode does spray out appropriate spray nozzle but when not pressed it spews water out the base. In wash mode, the cleaner does not spray but water continues to leak out base.
    President:
  • 1,673 Answers
Check the valves at the bottom of the tank(43513026)also check for cracks in the tank(42272104). Another thing to check is the handle asm. is a rod that pushs on the resevoir asm(tanks sits on) to make sure that it is stuck in the on position. Depressing the trigger and watching, you should be able to see if it is moving up and down ok.
Posted on Feb 14, 2008
My Bissell will not spray water out on the floor but the hand tool works fine. Need some advice on what to check
First check fluid levels. Check Bladder level is full and Heater tank level. Sounds silly but you never know
1. Check the tank seating. If the tanks aren't seated corrected they won't work correctly. Turn off and unplug unit. Remove tanks and reinstall them.
2. Check filter. It may be clogged. This is the "FLOW INDICATOR". Remove the cap and rotor. The filter is just below the rotor and cleans by back flushing. CAUTION: don't drop it down the drain.
3. Check pump belt. Belt can break and cause the problem. Turn off unit. Turn unit back on and check too see the DirtLifter PowerBrush turns. Refer to NOTE below if brush doesn't turn.
4. Reprime pump. Loss of prime can happen if fluid levels are low. Turn unit off for 1 minute then turn unit on and press the trigger.
For all checks it is best to turn unit off and unplug it. NEVER USE ELECTRICITY WITH FLUIDS.
BROKEN BELT: Turn the machine off and unplug it. Move it to a dry area. You will need a flat head screwdriver.
NOTE:
Insert screwdriver into the lower slot of the belt access door to release the lower snap (on left side of unit as you are looking from the front about an inch up behind the adjustment knob) If necessary insert the blade end into the upper slot to release the upper snap. Examine the belt for breakage. If broken, refer to your User Guide for replacement parts. Installation instructions will accompany the replacement.
Dec 30, 2015 | Bissell 1693 PowerSteamer Upright Vacuum
The hand grip of my Hoover FH50026 does not work. I press the handle grip, but no liquid goes out
It may be the trigger inside the handle is broken. The trigger pushes a rod that goes down to the valve at the bottom of the fresh water tank to allow the water to flow out.
Feb 16, 2015 | Hoover Vacuums
We have a Hoover Steamvac F7452 that is leaking water from the bottom of the machine. If we place the water tank on the machine, water immediately starts flowing through to bottom of the machine. It'
When you put the tank on it connects with the unit and opens the valve on the bottom of the tank to allow the water to flow check for debris hair etc around the connection, it is possible the seal itself is worn or bad and needs replacement but I think the trigger only lets air in the tank so the water will flow out by gravity, I'm not positive on this but mine works that way.
Oct 19, 2014 | Hoover F7452-900 SteamVac Upright Vacuum
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Water doesn't circulate from the tank to the rug
Have you checked for the sprayer nozzles under the clear vacuum housing are not plugged with some foreign debris, carpet fibre buildup etc. Place the unit on bare floor and engage/turn on the motor/pump and pull the trigger/switch? No water? Check also that the hose/attachment wands have water or not? If they are operating then the nozzles to the carpet off the main unit may need to be cleared by using a pin (Safely) se if there is no foreign debris in sprayer nozzle. I have seen soap solution gone crystalized and the minute pieces clog up the on board prefilter and yet somehow clogs the nozzles as well. you may have to take the top of the unit off (approx. 6 screws) and see if there is water flow or maybe a kink in water /sprayer/nozzle line. Good luck
Apr 30, 2010 | Bissell 1699 ProHeat Clear View Upright...
My hoover steam vac is losing all the cleaner and water out of tank the trigger isn't stuck
You will need a resevoir. This is the valve that the solution tank sits on when put on the machine. If your exact part number is not available ask to look at another model series, you may get a different colo but you will have a working steam cleaner.
Apr 07, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
350 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
