Question about Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive
Toshiba drivers I have a new pc and need to transfer a program to an old pc. The old pc doesn't recognize nor give Toshiba as an option to find on the PC; it asks for a CD or floppy, which I don't have. I have been searching online but find nothing. Is there a way around this? Maybe you know of a place I can download the drivers from. Thanks, Iris iriselizabeth@msn.com
  • majadel Jul 08, 2008
    i have a laptop with vista operating system any time i insert my 1GB toshiba flash it ask me of the driver which i donnt have, cann anyone help pleas?
There is no transmemory yet pls. add this as soon as possible!
Posted on Aug 01, 2008
  • 42 Answers
You can go to the best drivers site and find your requirement
http://downloaddriver.com
http://driversguide.com
Only you have to register on it by simply procedure its free
Regards
Balisonu79
Posted on Feb 14, 2008
Files from a back up
You should be able to plug the external hard drive into the new computer and restore. Generally the drivers needed to access the external driver are on the external drive itself. The operating system will detect the hard drive (if it has plug-and-play services running). If the new computer fails to see the external drive, check the cable and download the driver manually from the manufacture's website. If the drive is recognized by the operating system, but you do not see a prompt to restore from the backup, you may need to locate a setup program on the external hard drive to start the restore process.
Apr 18, 2014 | Computers & Internet
How can I transfer data between two primary hard drive after replacing one
Windows needs to be installed on the new primary hard drive and also thecomputer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Jul 09, 2012 | Toshiba Computers & Internet
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
Does Alohabob PC backup give you the option to reinstall start menu programs from the backup, just as they were in your start menu before you backed them up, Rather than reinstalling from CD/DVD's? I...
If it truly is backup software then yes and no. Yes it can back up the programs but a lot of the time there are registering of DLL files and registry settings that don't get backed up and there for the programs wont work. So backing up programs is never a good idea. You can however download some free software such as EASEUS. This program can do drive to drive copy this would allow your programs to be copied over and work on the new hard drive. You could also get Norton Ghost and create and image disc and use that as well to essentially move the programs and data to the new computer.
Comment if you need further assistance.
Aug 15, 2011 | Eisenworld Alohabob PC Backup for PC
I can't get my new MacBook to recognize and import photos.
Mac's don't need a driver to recognize the camera however they usually need a specific program for different brands of photos. You can also try opening up iPhoto as that will usually recognize the camera. If iPhoto doesn't work and you don't want to install a new program you can also get a card reader that'll connect via USB and will avoid needing any program to transfer photos.
May 11, 2011 | Fuji FinePix S1000FD Digital Camera
I have a toshiba harmon/kardon laptop and the web cam does not work. I have tried everything and a message error pops up saying that it is being used by another program or the computer does not recognize...
you will need to go to the toshiba website and download the driver for your webcam, uninstall the old driver and reinstall the new one. that should be it :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 03, 2009 | Computers & Internet
Need to know how to transfer programs and files from old to new PC
There are three sets of items that you need to transfer.
It would be best to use an external USB drive and keep the data on the drive as a backup.
1. Settings (Internet favorites, desktop settings, cookies, address book, etc.)
2. Data (My Documents, and multimedia content)
3. Programs
It would be easy if the old computer was also a Dell; however, you can't simply "copy" to the new computer.
#1. Settings: There is a built-in utility called "Files and Settings Transfer Wizard". [Start] [All Programs] [Accessories] [System Tools] [Files and Settings Transfer Wizard]
#2. The transfer wizard has an option to copy "settings only", "Data Only", Settings and Data". Transfer only the settings and then transfer the data. It will go much smoother.
#3. Some programs are already on your new computer; however, unless the old computer was also a Dell, you will have to re-install most or all of your programs like MS Office, Printers, Scanners, Camera and Video applications, etc.
If you need more detail, please post a comment... Thanks .
Oct 08, 2009 | Dell Dimension 4600 PC Desktop
Toshiba Pocket Pc e335
The are no drivers all you need is the activesync program from Microsoft. Activesync is the program that comes with all windows mobile devices for transferring data between your PC and mobile device.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 01, 2009 | Toshiba e335 Pocket PC
Vista machine doesn't recognize drivers so can't transfer files from old PC to new one (with Vista). Any updates?
what do use to transfer? usb stick or network connection?or cd/dvd-r?
what os does your old machine have?
if both machines have valid and functioning OS(winxx) and both have usb 2.0 port,
and you are transferring just back-up of personal data (doc's, mp3's, save-games etc., use) that amount up to less than 1 GB, try using usb-stick or empty mp3-player for file swapping.
else burn the files from old machine using the hopefully available cd/dvd-burner in it and transfer to newer.
for easily transferring the whole content of old harddisk unaltered,
set up asmall win-home-network using dsl/lan-cable plus crossover adaptor
(wire up both machines to one-another) and stream old harddisk content to new machine
is it laptop to laptop-transfer and you are somewhat familiar with hardware?
remove harddisk from older and put into new one!
by the way: if you can have win xp pro installed on newer machine for same or less price of win vista, try to get it(you do need a bit computer expertise - but we all like learning -don't we?
good luck, if not satisfied or too much options for one time, just comeback to me!
sincerely yours
Jun 16, 2009 | Eisenworld Alohabob PC Backup for PC
Computers & Internet Logo
279 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
