Question about Whirlpool ED2FHSS Side by Side Refrigerator
Water dispenser doesn't always work
I have a whirlpool ed22toxfw00 side by side. What could the problem be?
  • dvldog Feb 20, 2008
    the problem was the water inlet valve, i replaced it... problem fixed
  • 1,314 Answers
Erratic water valve the ice and water are on seprate valves and the water side could be sticking
Posted on Feb 14, 2008
Control panel does not always work
What control panel? The panel that dispenses water or the control panel inside the fresh food compartment? What is your model number?
Sea Breeze
Apr 02, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side fridge won't dispense water.
Most likely the problem is related to a defective water control valve on the dispenser side of the valve. If your model is the ED2FHEXN it will use the=> W10408179 Water Inlet Valve
You should always turn the water supply off before removing the filter cartridge just to insure less water clean up should a water valve be stuck open. At this point I still believe that the water control valve is at fault for not allowing water flow to the dispenser. Here is a parts manual=> ED2FHEXN Parts Manual and here is a link to your ED2FHEXN User Manual You may get some water flow spraying should there be a valve stuck open but that is not the cause of you not getting water to the dispenser. Your ice maker is still working right? I will be here should you have questions or comments, Thanks Sea Breeze
Mar 05, 2013 | Whirlpool ED2FHEXN Side by Side...
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Water dispenser has stopped dispensing water. I have a whirlpool 25.4 cu ft. Side by Side Refrigerator
there are a few things to check real quick
does your ice still work
does your ice make still work
when was the last time you changed the filter
when you do call for water can you hear the water solonoid
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser not working on my Whirlpool side by side
cheek out the soloniod valve at the rear side of the refrigerator.and then cheek the pipe it should be stright.
May 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Side by Side Refrigerator
hi. thanks for the question .in the front of fridge where the ice # water is located . inside the door ,there are two switches and they don't always make contact. work with it, till it gives out completely. thanks the appliance doc. please rate me thanks
Sep 22, 2008 | Whirlpool GD2SHGX Refrigerator
Cold water dispenser on new whirlpool side by side dispenses lukewarm maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
