No, not directly. There is no SATA header, (Connector), on the motherboard, and you have no SATA power cable on your power supply.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm
HOWEVER, you can buy, and install a SATA Adapter Card, and use a SATA adapter cable, on a certain power cable you have already.
The SATA adapter card goes into any available, (Open), PCI expansion slot on your motherboard.
(White slot on motherboard)
This is an example, (Not an advertisement for said manufacturer, nor website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329305&CatId=1455
You will also need a SATA data cable, to hook that SATA DVD player up to a SATA adapter card.
(7-pin connector on each end of the cable)
As said, you can convert a certain power cable on your power supply into a SATA power cable. (15-pin connector, on the SATA end of the cable)
The power cable is a Peripheral power cable. It will have a 4-pin Molex connector on the end.
If you have an unused Peripheral power cable, an adapter power cable plugs onto it. The other end of the cable has the SATA power connector. (15-pin)
Will give examples of a Peripheral power cable, and a SATA adapter cable, in an additional comment.
SATA adapter power cable,
http://www.directron.com/idesatas4to2.ht...
(Has two SATA power connectors on the end of the cable. {Black.
White single connector is a 4-pin Molex connector)
Peripheral power cable example,
http://www.playtool.com/pages/psuconnect...
(You can also scroll the page all the way up, and click on the photo of the SATA power cable)
Better view of a SATA header,
http://en.wikipedia.org/wiki/SATA
Photo all the way to the right, on the top of the page.
Not all SATA headers are red in color.
Looking at this example, you will be able to pick out the SATA headers on the SATA adapter card example, I gave above.
An example of a SATA Data cable, (Orange), and an adapter cable for power,
http://www.newegg.com/Product/Product.as...
(The adapter power cable converts using a 4-pin white Molex cable connector, to a 15-pin SATA power connector)
SOURCE: Help with burning a DVD
you can't copy the DVD movie as files. although you will see the movies files in chapters.
I don't have any luck using Nero or Roxio for Movies, they are OK with video copy.
I use DVDFAB. there are somting regular DVD writer just can't do.
SOURCE: How to install a dvd and cd player in a Dimension
I actually had this case.
When you want to install a DVD and a CD player into a Dimension 2400, you will need to do two things.
1. On the DVD and CD player you will need to install a screw that has an insert on the end of it so it will not go in all the way. You will need to search for those screws from a hardware store. If you can't, just contact dell and they can send you out those screws.
The two screws closest to the front of the case receive them. The other one that you can access closest to the power supply receives just the ordinary screw that you use to secure a hard drive.
2. Once you have done this, just set the master and slave on the appropriate drives and connect them with a ribbon cable on the secondary IDE controller.
Just make sure to have at least a 350 Watt Power supply. A 300 Watt one will work, but it won't give you much room for expansion.
