Back to:
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Emerson Model MWG9111SL Microwave not always... (by 5 users)
posted by sfrey69 on Feb 14, 2008
My Microwave works Great sometimes, But to often when I try to heat something up, no matter what setting or time I use the Microwave does not come on. The Light works,turntable spins, timer counts, but no noise or heating.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by ashlyw74, posted on Sep 05, 2008
My microwave wont heat things up. It works sometimes other times theres no light and no heat. I am incredibly frustrated because I havent had it for more than 6 months. What can I do to fix it?
Comment by aplusser, posted on Aug 15, 2008
My microwave is doing the same thing. It wont heat up. Ive tried unplugging it, different settings etc. Sometimes it would take 20 minutes to heat something that normally took 2. Im so frustrated!!! Anyone know if there is a recall? Cool microwave but it only worked right for about 4 months!
Comment by Guest, posted on Jul 16, 2008
my microwave wont heat
Comment by mark19518, posted on Feb 23, 2008
Try all the settings but can not get the microwave to heat.
Best Solution
posted on Feb 15, 2008
Helpful (85)
Totalwreck
Rank:Wiz Wiz
Rating: 86%, 40 votes
Every thing works, but no heating and no noise. I am happy you had noticed that there was a difference in the "Noise". Some describe it as a vibration you can feel in the cabinet. The "Noise" is only present when the High Voltage Transformer is engaged. The "Noise" is a low Humm which The High Voltage Transformer emits. Without The High Voltage the unit will not Heat.
BECAUSE you say it heats Sometimes. I suspect a LOOSE CONNECTION between the Low Voltage (115v) and the Primary of The High Voltage Transformer. Could be a Solder Connection, or just a Loose Wire. Loose, not Open. If it were OPEN it would not "Cook" at anytime.
Rating Locked! (?) sfrey69 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Emerson Model MWG9111SL Microwave not always working:
I don't want to Accept this solution
Solution #2
posted on Sep 07, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
RETURN IT BEFORE YOU BURN YOUR HOUSE DOWN....
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
Not Rated (0)
msexton_90
Rating: 0%, 0 votes
my microwave is not heating
Thank You!
Can you Help with these Microwave Ovens problems?
GE JVM1850 1000 Watts Microwave Oven
my three year old microwave went out about three months...
Microwave Ovens
the door handle broke off of my built in microwave ...
Panasonic NN-S933BF / NN-S933WF 1300 Watts...
When a time is set and the unit is started, it will turn...
Microwave Ovens
selecting program but not functioningonn
Microwave Ovens
how do I set power to "medium" or...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
