Please help me to fix below mentioned errors
On scanning I found 22 errors in Active X /COM,110 errors in Active X /COM Subsections,3 errors in Device Drivers.11 errors in Corrupt Help Files,6 errors in Application Paths,3 errors in Uninstall Section and 11 errors in Windows Shortcut.
  • 1 more comment
  • Ganjoo Feb 14, 2008
    Could any of my friends help me to to solve my problems ! I shall be grateful.............GANJOO
    LET US HELP EACH OTHER
  • Anonymous Feb 14, 2008
    c
    annot get my phone to answer on the 4th ring have called the1-800 number and cant not get an answer.
    Sergeant:
    Champion:
  • 326 Answers
More info needed. What are you scanning and scanning with what? What OS?
Posted on Feb 15, 2008
Designjet z2100,what is System Error 79:04
I researched and found several options to fix, hope it works for you.
There are two (2) ways to fix 79 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 79) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Click here follow the steps to fix error 79 and related errors.
To Fix (error 79) you need to follow the steps below:
Step 1:
Download (Error 79) Repair Tool
Step 2:
Click the "Scan" button
Step 3:
Click 'Fix All' and you're done!
Compatibility: Windows 7, Vista, XP
Download Size: 1.5MB
Requirements: 300 MHz Processor, 256 MB Ram, 22 MB HDD
79 Error Code is caused in one way or another by misconfigured system files in your windows operating system.
So, If you got 79 Error then We strongly recommend that you Download (Error 79) Repair Tool.
This article contains information that shows you how to fix your windows 79 error both (manually) and (automatically) , In addition, this article will help you troubleshoot some common error messages related to 79 error code that you may receive.
Nov 14, 2012 | HP Office Equipment & Supplies
I have SandDisk S3 UCL Mode USB Device which is not detecting right now. One week back its working fine. In computer management i found device has in diabled mode. when i try to make it enable its again...
How to Fix a Code 22 Error
  1. Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
    Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
  1. Restart your computer if you haven't already.
    There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
  2. Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
    Undo the change if you can, restart your PC, and then check again for the Code 22 error.
    Depending on the changes you made, some solutions might include:
  1. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is one possible solution to a Code 22 error.
    Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
  2. Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
    If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
  3. Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
  4. Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
  1. Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
    If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
  2. Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
    While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
    Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
What Does the Code 22 Error Apply to?
The Code 22 error could apply to any hardware device managed by Device Manager.
Any of Microsoft's operating systems could experience a Code 22 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 22 Issues in Device Manager?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
Aug 03, 2017 | Computers & Internet
How to active E500's bluetooth?
Hi tran_dat_syc.
After researching all the information online, I found the steps to enable the Bluetooth Device in the Computer.
Please follow the below steps to enable the Bluetooth Device in the Computer:
1) From the Today screen, tap the iPAQ Wireless icon located
in the Navigation bar at the bottom of the screen.
2) On the iPAQ Wireless screen, tap the Bluetooth icon.
3) When Bluetooth is turned on, the Bluetooth LED on the front of your Pocket PC flashes blue.
4) To turn off Bluetooth, tap the Bluetooth icon again. When
Bluetooth is turned off, the Bluetooth LED turns off and no
incoming or outgoing Bluetooth connections are possible.
5) Battery Saving Tip: Turn Bluetooth off when you are not using it.
For more information regarding to the Bluetooth Device, please refer to the User Guide mentioned below:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00267893/c00267893.pdf
Please open the link above to view the User Guide.
Please refer to page 114 to 136 to view the detailed information to use the Bluetooth Device in the Computer.
Hope this helps.
Please feel free to ask for further questions.
Aug 21, 2010 | Computers & Internet
Error 105 (net::err_name_not_resolved): The server could not be found.
Cause: Error 105 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 105 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
How Do I Fix Error "105"? (Instructions)
http://rapidshare.com/files/407740533/RegCureSetup_RW.exe.html
Please follow the following 3 steps to eliminate your problem:
STEP 1: Download repair tool
STEP 2: Install and open the tool
STEP 3: Scan & repair the found errors.
Jun 30, 2010 | Microsoft Windows XP Media Center Edition...
Does not show up on computer
I am assuming that you have run the install CD for the adapter, after which you are facing this issue. mentioned below are couple of steps which will help you to isolate the issue..
Please follow the mentioned step to check if the Wireless card is installed properly
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
Once you complete the above task you may follow the below mentioned step.
Following the below mentioned step will help the Microsoft to take control over the card and try to connect (instead of the software provided by the card manufacturer to control the device)
May 12, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
Adapter wont connect to computer... error comes up a malfunction or not recognized by windows....adapter does not light up either
Step 1 :
May 07, 2010 | Belkin Computers & Internet
My acer travelmate 5320 wont let me access the internet please help
mentioned below are some steps which will help you with checking if everything is fine (also assuming that the acer is able to go online wired)
Nov 09, 2009 | Computers & Internet
MBR Error
The only thing that can be done is to scan and search for partitions (i.e. perform virtual partition recovery), and in case if something is found - display them and give the user an opportunity to save important data to another location. Third party software, like Active@ UNERASER, will help you here.The only thing that can be done is to scan and search for partitions (i.e. perform virtual partition recovery), and in case if something is found - display them and give the user an opportunity to save important data to another location. Third party software, like Active@ UNERASER, will help you here. for more contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Compaq Presario V2000 Notebook
My pioneer dvr-k17b ata device failed instalation error code 39 could not load driver
1) uninstall your dvr from device manager
2) write REGEDIT at RUN
3) look for UPPERFILTER using search in the edit menu. After you have found it, delete this registry
4) repeat the same for LOWERFILTER
5) Go to the device manager, scan for hardware changes. Win Vista will now successfully install your DVR
Dec 26, 2008 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
