Question about Refrigerators
Ice full sensor on all the time in a portable danby 1524 icemaker.
    Problem Solver:
  • 7 Answers
Have you looked at the manual yet?
Posted on Feb 14, 2008
  • c h Feb 14, 2008
    I did a bit of online research, since I couldn't find the manufacturer's site. It seems this unit can have many problems from ice going where it's not supposed to be, from melting ice. That's because it does not have a freezer component, so the ice melts once the unit gets full. It's not hard ice either, so it melts faster.
    So it apparently needs frequent maintenance, you need to use the ice often, I guess. You should unplug, do a good cleanup, drain, etc, start over.
    The back of your user's manual usually has solutions to common problems.
Do the ice makers shut off automatically when full?
The icemaker has ice level sensor located inside the ice bin. Once ice cubes reaches the sensor, it cuts out automatically and starts once the ice level drops
May 03, 2016 | GE Refrigerators
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
The ice maker stopped making ice one day
A typical problem with these is some type of bin sensor that tells the icemaker that the bin is full. it is usually some type of "arm" that shuts it off when the ice rises to a level that raises the "arm" to "kill" the icemaker
Oct 01, 2012 | Refrigerators
How do I control the amount of ice in the freezer? When I open the freezer door ice pours out onto the floor and in the freezer itself.
That is going to a internal problem in the icemaker,is has a sensor that when it detects that the ice bin is full its supposed to cut off the icemaker so it doesnt overflow and continue making ice such as your experiencing. By replacing the icemaker it will shut off when the storage bin is full.
GENE
Sep 26, 2011 | Refrigerators
I purchased a koldfront portable icemaker KIM202W from living direct (online) in Austin. The ice full indicator light stays on and will not allow for refill of water. I have read the manual, turned off the...
have you checked to see if there is a ice full bin sensor that may be dirty, iced over, or something similar - there has to be a sensor that will tell the system to shut off when the bin is full and it's got to be blocked by something - Good Luck - Eric
Oct 02, 2017 | NewAir Kitchen Appliances - Others
I have a ge fridge it got a icemaker on it it works good but the flap wont let the ice fall down in the glass
ice sticks together, what pushes the ice out? gravity ,
hyperlink for the danby dcr412
http://www.ajmadison.com/ajmadison/itemdocs/dcr412productmanual.pdf
Nov 15, 2009 | Danby DCR412 Compact Refrigerator
Kenmore fridge optical icemaker hosed
ice maker module assembly is probably broken
Sep 27, 2007 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
