Monitors
Problem for Monitors
Generic problem for all Monitors
Hooking the monitor/computer to cable
By KristineErin on Feb 14, 2008
I purchased a new LG 24" Flatron monitor yesterday from Future Shop. It was a floor model so I do not have instructions is there any way you could send me an instruction manual? I am trying to figure out how I connect to our satelite. Email address is e.logue@mailcity.com
Thanks
Erin
Same Problem
Aug 05, 2008
-   I had to unhook everything because I needed to move my desk. I thought I had hooked everything up O.K. but now I have no sound. I am not sure if I hooked it up right. Can you help me?-   dg7379
Solution #1
posted on Feb 20, 2008
Not Rated)
kishkane
Rank: Wiz
Rating: 76%, 159 votes
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
monitor comes on for about 20 seconds, Then goes dim
Answer
sony wega mbdxbr950 my pdm4210 wofire upnt
Answer
dell E153FP main menu keep popping up in the middle of mt screen
Answer
vertical lines when you press power after a few mn the monitor become ok.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
