Question about ASUS A8N-E Motherboard
Motherboard may have fried MB but not sure. computer kept shutting down, couldn't reboot (getting a no config.sys notice) finally rebooted did a "repair" install of windows( I know they're usually no good but didn't want to go through the hassle of installing drivers again), worked fine for a day then shut down and now won't reboot with windows CD, it does the initial windows xp setup then as it gets ready to install windows tells me there's no HD. HD is good, got stuff off it. Once I tried starting it in safe mode, then I got the blue screen of death once I picked a user
  • 20 Answers
Check ur BIOS setting.. set the default BIOS setting n try installing with another windows CD.. I hope if ur HD is gud thn It'll work.. BEST of LUCK!
Posted on Feb 14, 2008
Random reboot cpu
try with a other PSU. proberly electrical problem.
May 11, 2013 | Intel DG41RQ Motherboard & Core 2 Duo...
Computer won't shutdown and usb's keep uninstalling
push and hold the power button it will shut down, after rebooting run Malwarebytes and tdss killer and remove any unwanted stuff they find.
Jul 05, 2012 | AMD ASUS A7N8X MB / nForce 2/ 400FSB/...
I noticed something called antispyware soft kept popping up saying my computer was infected... I tried to do system restore but it wouldn't come up. I shut it down and tried to reboot in safe mode and get...
You fell for malware that is sent to 'infect' unsuspecting users. Since it will not boot up now, the best is to wipe the disk and install from scratch. A recovery disk from the same type should work, but no guarantees.
Jun 14, 2010 | E-Machines (308714) Motherboard
I can not install ALCXWDM.SYS to enable my speakers as the computer shuts down halfway and reboots
Try uninstalling all the drivers in the add/remove programs in the control panel and removing the device on the device manager.. Reboot and install again... if problem persist than possibly hardware is faulty..
Nov 15, 2009 | ASUS P4S800-MX Motherboard
Aopen mx36le-un motherboard replaced
If your HD is connected via IDE (a wide, flat cable) try reversing it. If not, go into the bios and make sure that your SATA ports are enabled, all IDE functions etc.
If not, your drive could be fried. If you have another computer to test the drive in, that would be handy.
Apr 18, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
Shutting down then starting back up whenever
Ya. If it keeps re-booting then it may be a virus (my things virus)
If not, go to system properties and start up and recovery settings. remove reboot on error settings (in XP) It doesnt fix the root cause but may stop your frustration
Apr 11, 2008 | Intel Motherboard
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
May 06, 2007 | Abit KN8 SLi Motherboard
ASUS A8N-E Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
