Question about Vtech IS6110 1-Line Cordless Phone
Can not dial out using the 3 6 or 9 - Vtech IS6110 1-Line Cordless Phone
  • kimiecake1 Oct 19, 2008
    I am having the same problem
I have the same problem
Posted on Oct 19, 2008
My phone works good now that I removed the battery for a few secons then put it back in. Thanks for all your help.
Louise Ragland
Posted on Feb 15, 2008
How to edit speed dial feature KX-DT333
To Program:
Lift handset. Press * 3 0 , then enter the desired 2-digit code (00-09), enter the line access code (generally ā€œ9ā€) followed by the telephone number, then #.
To Use:
Lift handset. Press AUTO DIAL/STORE * plus the 2-digit code (00-09).
To Use System speed Dial:
Lift handset. Press AUTO DIAL/STORE plus 3-digit (000 - 999)
The User Guide can be found at the link below. Hopefully this helps.
http://www.manualslib.com/manual/853264/Panasonic-Kx-Dt333.html
Jul 23, 2016 | Panasonic Lands Phones
How can i use conference call in samsung sch w279
while on a call, dial number and then again dial no which you want go for conference. 1st dial no is on hold position and 2nd dial no is on activate mode. then press 3 button(numerical no) and press dial button in order to use the conference call.
Jan 04, 2013 | Samsung Vitality SCH
Speed dial does not work
Look at the number that is in there for the person you are trying to speed dial,your voice mail is always #1.To use speed dial you just use the number the person you are trying to speed dial lets say they are in your phone as #2,hold down the # 2 on your keypad for around 3 seconds and it should start dialing.
Jan 01, 2013 | Net10 Motorola W409G Prepaid Camera Phone
How to conference a call in a siemens euroset 2025c?
You need to change the Pause time from 3 second (Default) to 1 second. For this First of all your have to
1- press the "set" key on the Euroset-2025 set and
2- then dial 1020.(1020 for 1 second pause) (1021 for 3 second pause)
3- and "set" key again.
Now you can use the conference feature of set.
Jun 16, 2012 | Lands Phones
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
I need to set up one touch dial fax numbers
This should be what you're looking for:
Storing Speed-Dial numbers
1 Press Menu/Set, 2, 3, 2.
2 Using the dial pad, enter a three-digit
Speed-Dial location number.
Press Menu/Set.
3 Enter the number (up to 20 digits).
Press Menu/Set.
4 Enter the name up to 15 characters (or
leave it blank).
Press Menu/Set.
5 Press Stop/Exit
Apr 23, 2009 | Brother IntelliFAX 2800 Laser Fax
Speed dial on uniden
When the phone is not in use, press and hold the number key (0-9) that is assigned to the phonebook entry. Press flash on the handset to dial the number.
Apr 23, 2008 | Uniden DCT756-3 Phone
Speed Dial for a Uniden Model DCT648-3
Do you have a copy of your owners manual? If not, here is a link to a pdf format version of it, from the Uniden website:
http://www.uniden.com/pdf/DCT648-3om.pdf
Speed Dialing
If you store a phone number in a speed dial memory location (10 locations: SPD1 - SPD0),
you can use the speed dialing feature. When the phone is in standby mode, press and hold a
number key (0-9) associated with the speed dial until the phone number appears and then
press talk/flash or speaker. The number stored in the speed dial (SPD1 - SPD0) is dialed.
Nov 30, 2007 | Uniden DCT648-3 Cordless Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Vtech IS6110 1-Line Cordless Phone Logo
107 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
