Hi there,I am in need of a power switch for a Sansui Stereo receiver model 9090DB.Sometimes I can't turn the unit off cause it sticks and I have to fiddle with it to get it to pop back out.I was planning on taking it apart to do a clean-up and Deoxit on all switches and controls.It would be nice to have a replacement power switch during this procedure.Can you help me out here?Thank you for any help you can offer....Rick
  • 98 Answers
No need to dis assemble ur switches.. go hardware store/electronic store buy a contact cleaner (aerosol)spray defective switches.
this will fixed ur problem..
ok pare
Posted on Feb 14, 2008
Voltage change 220v 240v
These number have no bearing with amp issue. It only means if you're in North America or International with 220 volts. However, your problem is power transistors
that are shorted which is the cause of fuse blowout.
Mar 13, 2014 | Sansui Audio Players & Recorders
I have an older (10 ) years Sansui am/fm receiver model rz-5500av. It performs well, but after a power surge, the fm radio will not play in stereo. The fm stereo indicator flashes on and off. I was told...
Part of the circuit is a stereo multiplexer decoder, that decodes the fm stereo signal, I guess that is what you mean when you talk about capacitor linked to the fm band.
I do not have the sbchematics for this circuit, if you are good at electonics just grab the tester and check the whole circuit. On a radio is not difficult to find a blown capacitor.
Test also the stereo/mono switch.
Sep 21, 2008 | Sansui Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
I have a Sansui G-4700 Pure Power DC Stereo Receiver. We were happy with it for many years. Five years ago, we moved from a house to a condo, and it has been in storage since the move. I am thinking of...
Of course it will work with any standard stereo RCA source (which just about everything STILL has) but it won't work directly with any digital sources. It has NO digital interfaces.
Jun 22, 2011 | Sansui Audio Players & Recorders
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
Stereo reciever takes several seconds to power up
The power switch is arcing internally and needs to be replaced. This is a common problem with some older receivers. Sometimes the switch can be opened and the contacts burnished.
Dan
Mar 02, 2009 | Audio Players & Recorders
I need a power switch for a Sansui 5000a Part number MSH501X, 125V, 3 Amp
hello
not to sure if any help but you could try here or email them see if they can locate one for you, Vintage Sansui stereo parts & salvage units for receivers.
riz.
Mar 20, 2008 | Audio Players & Recorders
85 people viewed this question
 Grubhead
Grubhead
