Question about Maytag Atlantis MAV6451 Top Load Washer
MAYTAG WASHER DOES NOT SPIN AND DOES NOT DRAIN
MODEL MAV 6451 FILLS WITH WATER, AGGITATES, DOES NOT SPIN AND NO DRAINGAGE. IF i LEAVE IN THIS STATE A HAMMING NOSE APPEARS AND STARTS BURNING SMELL AND MASHIN 'DISCONNECTS' - DEAD. WAITING FOR 1/2 HR WILL START IT AGAIN - NO SPIN NO GRAINAGE
THANK YOU
SAL
  • 552 Answers
Something may be stuck in the belt or inside of the machine.
The following may help.
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Posted on Feb 14, 2008
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
GE washer wont drain or spin, lid switch has been replaced and so has the timer. At the start of cycle it fills and aggitates properly.
If the machine tries to spin for a few seconds and shuts down because the tub is full of water, then - The first thing I would do is check the pump. You may have something blocking the pump or the pump could have failed. Newer models built within the last 10 - 15 years must drain their water down first before they are able to spin.
Jul 28, 2010 | GE Washing Machines
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
Feb 18, 2009 | Maytag Washing Machines
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Atlantis MAV6451 Top Load Washer Logo
1,983 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
