Televison & Video Logo
Posted on Feb 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Philips 30inch flat screen. After half hour of use right half of screen turns all black. THe other half works fine. Audio OK
Michael Borelli
Level 3:
  • Master 979 Answers
  • Posted on Feb 15, 2008
Michael Borelli
Master
Level 3:
Answers
979
Questions
Helped
328491
Points
1751
Time for display unit..Sorry...accordianman
Philips 42PFL5405h/12 - Black screen and no audio on turning on.
It sounds that the settings have been corrupted. It will be best to contact the authorized service center to make this set right. Beware, not to make any experiments hereafter. It's 'PHILIPS'
2helpful
2answers
Half TV screen is black
you have a bad Y Sustain board or X Sustain board
undo the back (if you know how to deal with electronics) and with the TV unplugged disconnect one of the board and turn on, see if works or not and try with the other one till find out wich one is.
Fosg2000, Rate me
2answers
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
I have a philips 50'' television, model #50pf9631d/37 with a flashing red light on power light, sometimes i unplugged the unit about 5 or 6 times for about an hour, then try to turn it on quickly with the...
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
2helpful
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
4helpful
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
