I have a viper alarm with auto start. when i start the car via auto start and put the key into the ignition and turn it and press the brake pedal to deactivate it the car shuts down. it wont start by turning the key it will only start and cut right off, but when i use auto start it starts fine and runs till i push the brake.
just start over go get a remote start for 130 bucks and be done lol you wont find a elec. glich unless it is tested at the time of outtage easist way out
You need to call Viper and talk to their tech support. It sounds like the viper is actually disabling the starter. If you have all of your paperwork from the alarm system there should be a book that can help walk you through the reprogramming mode. Maybe your key fob is not synced to the alarm system. I have a clifford alarm which is still a viper. I have to press the star button 3 times in a row if I want my car to start remotely. hope this helps some.
Well it is if you want the auto start feature, you need the extra key to clarify the transmission for it to have the auto start feature, but if you want just the alarm you dont need the extra key!
Check brake light switch behind brake pedal remote start has to be wired into switch so vehicle will shut down when brake is depressed when put into gear without ignition switch turned on. possible bad connection on switch or wires are not attached.
put key in door lock,unlock/hold key over windows will go down....then lock/hold key over,windows will go up,press and hold unlock button on remote for 30 secs,you have just reset the alarm/immobiliser.
Brake light comes on auto each time you start the car (saftey check) and will go off when you press brake pedal.
Blinking arrow will stop when you click seat belt together (driver)
turn ign off press key in towards drive stem and turn anti clock (5degs)and pull out
Put in key hold in mileage reset button and turn key to on (dont start the car )the last click before starting (and keep finger on miles reset button till flashing stops
then turn off ,this resets all service lights,
tc
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Yes this is an Alarm issue that's why your vehicle is shutting down as soon as you press on the brake pedal. Is this an aftermarket alarm or stock alarm? Sounds like aftermarket alarm to me and if it is, the way fix this issue is as soon as you put the red n black terminal on the battery and the alarm goes off press your alarm key right away to turn it off. If this doesn't work put your key on the ignition after you have installed the battery and just put it on the "ON" position engine OFF then click on your alarm remote once again.
