Question about Dell XPS M170 Notebook
Turning of LED's
How do i do it?
Go to Dell's Support website and download the LightFX software. The direct link to this download is here.
Hope this helps!
talbottsw
Posted on Feb 15, 2008
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
Tip
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 | Cell Phones
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
LED motion sensor lamp, after installed, does not turn off, it is on all day long
usually motion sensor led lamp is a little different from general led lamp. the work condition will shift from general lighting to motion sensor light. The reason why installed, but can not turn off, might you install in the wrong way. You can see the installation details Pir Sensor Led Tube 4ft f328a61c-a223-4610-b54f-1ba4836154f7.jpg
May 28, 2012 | Home Security
Imac intel will not power on
Possible failed video card. 3rd LED indicates MLB and GPU are communicating: (CAUTION! There is high voltage from the powersupply so any attempt to open iMac other than removing glass panel to see the indicators...should be done by authorized ACMT)
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Aug 01, 2017 | Apple 24" iMac Desktop
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
LED Lights wont work
if the turn signal worked before try to change the wires to the led, make sure the positive is on the correct wire to the led.(switch them)
Also make sure fuse to turn signal is still good.
Apr 17, 2010 | 1982 Honda GL 1100 Innerstate Gold Wing
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Dell XPS M170 Notebook Logo
54 people viewed this question
Alun Cox
