Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Beeping Hi , one day the tv just went black , no pic , no sound, but it has a beeping noise coming from it, I see one person said it was the ic"s "stk392-180 , I had it checked out and the said the h/v generator was bad, which one is it more likely to be, the generator or the ic's, or should I just replace all three since im there, plus what kind of soldier do I use on it. thank you
  • 1 more comment
  • PETERKIPP Feb 20, 2008
    well I fixed it, I figured since the guy who checked it out already had the h/v generator out that I would just replace it first just to see, that fixed it.
  • Anonymous Mar 26, 2008
    i have a phillips tv 28 widescean 28w6615 i have volume but no picture.plz advice what is the problem?
  • What A Piece Jun 05, 2008
    I am sorry is the soldier used to de-sotter the H/V Generator from the main panel? And if yes what type do I use and where can I get it from.
    Thanks.
  • Philips Master
  • 3,459 Answers
I had the same problem. You need to replace one IC chip. Check www.magnavoxhelp.com for instructions and a kit.
Posted on Jun 28, 2008
    President:
  • 4,402 Answers
  • High-quality .040" diameter solder
  • 60/40
  • 370°F melting point
  • I will place my bet on the ic's.. you should be able to get a good price at mcm electronics
    Posted on Feb 15, 2008
    It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
    Samsung LCD TV with no video and high pitched sound - Digital TV ...
    www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
    Jan 7, 2010 - 26 posts - ‎15 authors
    Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
    Samsung LCD Green Screen - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
    Jun 11, 2015
    Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
    Jun 11, 2015
    Samsung DLP crackling/static noise
    Jun 11, 2015
    LCD TV making clicking/cracking sounds
    Nov 24, 2006
    More results from www.cnet.com
    Samsung LCD Loud Noise and Green Vertical lines at Start up ...
    www.badcaps.net > ... > Troubleshooting TVs and Video Sources
    Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
    No picture still have sound HELP
    If you have not tried it: unplug the set and if using a cable or sat box unplug that as well---wait for a while and plug both back to see if a reboot of either cures the problem or not.
    May 25, 2012 | Samsung 50 in. Plasma TV
    I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
    Try with that...
    http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
    Symptom:
    Sound but no picture.
    Cure:
    Master or Slave inverter is defective.
    It can be that the driver IC is defective or MOSF
    inverter transformers, or 470uF 35V C
    Replace driver IC BD9897FS or MOSFET's.
    996500046243 IC BD9897FS
    996500046242 Mosfet FDD8447L
    996500046241 Zener KDZ100V
    Oct 18, 2010 | Philips Televison & Video
    Was watching tv there was a flash of light picture went out and no sound either red led power light comes on but thats it no pic no sound
    Replace Both of your STK ICs nd 6 resisitors they are big black ICs will have part # on them STK392-110s .
    RK42-RK 46-RK50-RK54-RK58-RK62
    3.3) -( 1.8) -(2.7 ) (1.5) (3.9)- ( 2.2ohms)
    Sep 25, 2009 | Hitachi 51SWX20B 51" Rear Projection...
    We turned it off heard a noise and now the red power light just blinks and the power will not come on again. Toshiba TV Model #32SF62 Serial #11100308
    what was the noise? POP!
    If so then a capacitor on the power board has fried itself. Most problems where the lighyt blinks and nno pic or sound or a breif logo and then black are as a result of a faulty IC or capacitors on the control board
    Sep 07, 2009 | Televison & Video
    Plasma tv repair question
    Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
    Started as 1 then 4 over 4 months
    Aug 10, 2008 | Televison & Video
    RCA 32 in TV no picture no sound just a beeping noise TV power is on
    HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
    Jul 20, 2008 | RCA 20F511T TV
    Sound no pic
    Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
    http://servicemanuals.vstore.ca/
    May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
    TV started popping then died
    sounds like the sound amplifyer IC in the set went bad and it holding down or blew out the voltage regulator. If your a tech first thing I would do is find the sound output IC and disconnect the main b+ lead and see if the tv will come on. if it did I would replace the audio output IC. If it didnt i would have to troubleshoot the Power supply for the missing voltage. if your not a tech its not advised to try to do this repair as there are no user serviceable parts inside this set. Seek A Pro to assist in this repair as there is hi voltage in this set even when its unplugged. Good Luck
    Jun 11, 2006 | RCA P56950 56" Rear Projection Television
    Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
    48 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
