Question about Baby Gear
Craftsman meter 82026 need info on the 2 fuses
I went to sears yesterday to see if i could send the meter in for repair the desplay only shows half of the numbers . the small fuse is no good The man at sears said they dont make the 82026 anymore
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave left on without anything in it except plastic spash cover
It's probable that since it was running empty, the magnetron overheated and a thermal cutout or thermostat located on the magnetron opened. Magnetrons may be protected by a therostat, which will reset when it cools, or a thermal fuse, which is a one-time use device. It is also possible that in some cases, a thermostat will fail when opened. Please refer to the drawing. In my professional opinion, people should not work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. One can find such information in our safety and disassermbly text files at _.
Posted on Sep 17, 2006
Loringh
  • 185 Answers
SOURCE: car won't start
The clicking you are hearing is the starter solenoid. This is a relay that applies 12 volts to the starter motor when you turn the key.
I agree with the parts man, it is probably your starter. Put your car on jack stands, (don't trust the jack itself to support the car with you under it) Disconnect your ground lead on your battery. When you get under the car there will be 2 (sometimes 3) wires attached to the starter. One is a large size wire coming from the starter. It will usually be red. There will be a smaller wire connected to a separate terminal on the startere. disconnect both wires. There will be 2 bolts holding the starter to the engine. Usually 1/2 inch or 9/16 size.. Remove the bottom bolt first. remove the top bolt and as it is about to come out you will have to hold the startere with one hand whilr you remove the 2nd bolt.. THAT'S IT
Take it to the parts store and they can check it for you. BTW, a new solenoid should come already mounter to the new starter.
Hope this helps. Good Luck Loringh
Posted on Oct 31, 2008
savdragon
  • 37 Answers
SOURCE: need a layout of my number fuse box to show what
Hope that helps.....good Luck.
savdragon
Posted on Mar 19, 2009
  • 376 Answers
SOURCE: need repair manual for craftsman model number
I don't know of an available repair manual, but you can get a parts diagram by going here... http://www.searspartsdirect.com/partsdirect/index.action Enter your model number, then scroll down to Subcomponents, and click on Transaxle.
Posted on Jun 30, 2009
keeperoffire
  • 106 Answers
SOURCE: 2006 suzuki forenza low beam problem
You should check the dimmer switch.It is the switch that is totally in charge of high and low headlight functions.
Posted on Oct 06, 2009
I need 2 belts for my Craftsman utility sharpener part number or90109. Where can I find them?
Sears web site will give you info re getting parts for craftsman products.
Aug 19, 2017 | Craftsman Garden
I need a 2 speed switch for craftsman Vac/leaf blower as well as the short cord
Go to sears parts direct for all craftsman parts.. you will need your model info... it will be for example 536.00078 just like that...decimal after the 3Rd digit.. likely on a sticker..
Nov 08, 2015 | Craftsman Garden
What do I need to be able to use my Snowblower attachment Craftsman 2 stage blower 486.24839 933 on my Craftsman Riding lawnmower YTS 3000
Michael Brady,
Here is a customer contact reference for your records. For help and evolvement. Sears Customer Phone Number Shortest Wait Best Support .
Here is a review and site you can navigate for your decision Craftsman Dual Stage Snow Blower Tractor Attachment .
This second link shows a Husqvarna as an option to your rider Sears com. If it does not apply. The following will guide you to success
I have best results in the past by utilizing this link Craftsman Riding Mower Tractor Parts Repair Parts . Repair help and ask an expert in their arena.
Open any manual, there, are options for contact and assistance. Here is a phone number in the meantime for customer service 1-800-252-1698. You will see this example.
Fare well
Sep 30, 2014 | Craftsman Garden
Rest hour/service meter on 24hp sears tractor
There is not a reset on the meter. The meter will automatically reset after 6 - 8 hours of use.
Apr 18, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Door worked, 2 hours later didn't- just hummed good weather
If it just hums when a button is pressed it could be the start capacitor. This sits next to the motor and is about 5 inches long and about as big around as a silver dollar.
May 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Riding mower will not start or brake
The two are seperate issues. The switch on the brake pedal is on the frame and is accuated by the pedal, not the rod or spring. If you are not confident with a voltmeter or test light, then the Sears tech will be the fastest thing to mowing again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | Craftsman Garden
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Motor works but does not move chain on half horse sears
Clutch? need more info.. wall mount or overhead? If it's wall mounted it could be the clutch, I don't think overheads have a clutch though. The first thing I'd do is get on a ladder and see if the chain is still attached to the sprocket... good luck
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Baby Gear Logo
385 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
