Insignia home theater amp, model IS-HC040917 600w 6.1 chan. Turned it off one nite, back on the next, no sound output now. I have two of these that this has happend to.
  • 2 more comments
  • Roger Shields
    Roger Shields Feb 14, 2008
    i have the manual, the unit powers up, display works, you can see the volumn scale go up when you turn it up. There is no output to the speakers like a relay isnt coming on. insignia told me it was internal, they know the issue, take it to a repair place, they will know what to do. i don't want to put a lot of money in it for something simple.
  • Roger Shields
  • Roger Shields
    I have down a reset. no change. The speakers all work. Insignia knows the problem, they just won't tell me because i am not a repair center. As posted I have bought 2 of these units and they have both done the same thing.
  • Roger Shields
    It is not under warrenty because I bought it off ebay, although it was new in box. I use a dvm and all that every day. (engine tech)
    Guru:
  • 1,894 Answers
  • dewan nafees ahmed Feb 18, 2008
    ok fine then if you dont want to go to the company this is what you can do..
    open the unit and see yourself for any burns and any open connections ..
    since you said u r able to see VOL up and down i think the problem must be in main board and not in power board..
    because if power board is gone then you cant get anything working in unit.
    so open and check the mai circuit board and look what has happened inside.
    if u r handy in electronics then
    you can also do some testing of the board of the proper voltage that is expected..
    if u dont have any previous experience then service center will be a best option
    Brigadier General:
  • 6,966 Answers
With the indulgence of the other posters.
Most current designs of this type of device uses some sort of micro computer to handle most of its functions. Having said that, perhaps what you can try is to do a systems reset. To do a systems reset, with the unit off, press on the TEST button. Without letting go, you need to power-on the unit till the display shows "SYSTEM RESET". This is illustrated likewise in the manual as link posted by maklean and coolguy008.
If this is not corrective, then it can be assumed that there is a systems/hardware failure. If all else works except the sound, then perhaps it is the internal protection circuitry of the amplifier that is activated due to defective components or speaker/wires as posted by the others.
If your concern has not been corrected after completion of the above procedure or the suggestions of the others, you may need to seek the services of a qualified professional as others have also posted.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 14, 2008
  • Louie  Role
    Louie Role Feb 14, 2008
    Hi again,
    Would you consider doing a Do-it-Yourself (DIY) test/diagnosis/repair?
    If yes, you need to be comfortable and familiar working with electronic circuitry and components, use of a DVM and/or a continuity tester and even perhaps a soldering iron.
    Additionally, a friendly reminder, opening the unit other than authorized service personnel would void the warranty.
    Should you want to venture, pls post back and perhaps the members of the Fixya community can walk you through generic/generalized procedures.
    Cheers.
  • Louie  Role
    Louie Role Feb 15, 2008
    Hello again trukdude,
    Appreciate your patience and post back.
    To summarize what has been tried/done and/or can be assumed so far:
    1. happened on first unit, tried 2nd unit and same occurrence;
    2. followed the manual and done a RESET;
    3. visually, unit is working but no sound, no relay click;
    4. no strange popping sound, burnt smell, arcing
    5. all cord, speaker wires, connections verified;
    6. all attached speakers tested good 4~8 ohms; and
    7. you are considering a DIY.
    What perhaps can be done:
    a. open the unit (no warranty issue to worry)
    b. do visual inspection - look for the obvious, burned resistors, loose connection, open fuse, discoloration, blistered capacitors, oil smear, anything out of the ordinary such as excessive heat build-up;
    c. look for a mini switch near the controller IC (if it's got one, manual full/hard reset);
    d. do initial voltage checks - logic circuits would have 5VDC, relay triggers would be, 12VCD, preamps and amps would have possibly +/- Supply anywhere from 18 to 36VDC. They would normally be fused (slow blow) separately from the system;
    e. run a separate amp/spkr connected to the Line Out or Aux Out of the Insignia IS-HC040917. If the external amps work, then problem is isolated to amp section.
    f. amp section wouldn't vary so much from basic designs. I suspect that you can wing it even with the absence of a service manual and/or schematic diagram.
    Would appreciate if you can post any updates. Good luck again.
    Additionally, may I extend an invitation to your continuous patronage or participation as a regular Community member of Fixya specially in your field of interest (Engines).
    Genius:
  • 1,665 Answers
Here is yoyr manual for troubleshooting (see p.36) the appliance.
It seems like to have a power supply problem.
http://www.insignia-products.com/skins/skin_1/Topics/Documents/IS-HC040917_Manual.pdf
  • 579 Answers
You have a pattern developing. Either the amps have a comon defect (which I didn't find when searching the net) or you have a problem in your system causing this. Try connecting it to some other speakers if possible for starters. Does the display show any sound levels so you know if the signal is getting to it for sure? Some amps will shut all the outputs off if it detects anything wrong with the speaker impedances.
Hope Ya Fix It!
    Genius:
  • 3,422 Answers
Actually there is no home made remedy to fix the problem as something has blown up inside it may be a capacitor or some wire inside.So i suggest you to get it repaired or you can even try some troubleshooting steps before contacting them:
Click HERE for the manual.
please call 1-877-467-4289 for further support.
If you have any other problems please feel free to ask.
Goodluck..
  • 796 Answers
Hello sir
  • isaac johny
    isaac johny Feb 14, 2008
    check the wire for loose connections and the wave or main volume shud be low
I cannot turn off the TV,with the insignia remote control
Read the first time start up instructions .. This is what worked for me.
Hold the power-on/off button down while simultaneously pressing channel up , repeatedly for up to 45 times. when the TV shuts off stop, release the on off button.
you should be able to turn it on and off, if you went too far (pressed up arrow too many times), go the other way (holding down the on off and pressing channed down) until it turns on again.
Nov 30, 2009 | Insignia Digital-to-Analog Converter for...
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
Unplugged insignia box replugged cannot access menu unit comes on
Plug the Insignia output to TV video 1. Turn on TV, set to video 1 source. Turn on Insigna. You should now have picture and be able to go through the set up again.
Dec 31, 2008 | Insignia Digital-to-Analog Converter for...
Cannot get home theater to work
use RCA cables from cable box (audio out) to the audio in of home theater .and if you also want sound on tv use second output on cable box to audio in on tv. if no second output -use output on home theater to input on tv
Dec 21, 2008 | Insignia Audio Players & Recorders
MY INSIGNIA HOME THEATER REMOTE NO LONGER WORKS & HAVE DISH NETWORK REMOTE BUT IT DOSNT LIST CODES TO PROGRAM AUX MODE
that remote don't support your insignia , you can get one that supports your insignia and the features of your insignia for about $15-$20
hope that helps and thanks for using fixya!
electech
Oct 20, 2008 | Insignia Audio Players & Recorders
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
358 people viewed this question
 Grubhead
Grubhead
