Question about Hitachi 50UX57B 50" Rear Projection Television
Optoma 65in rear projection HDTV
The problem I'm having is on the far right portion of the screen. It's a darkened bar about 3in in width and goes from top to bottom. Is this an expensive fix? Also, I'm only home for a short period before returning to Iraq for the remainder of my deployment so time is crucial. Can someone please help me? Thanks in advance!
Steven
home: 915-613-0088
  • souljaboy78 Feb 18, 2008
    I don't kow. I've been deployed to Iraq. My wife doesn't know what happened. She just noticed it one day. If the mirror is off, how do I fix it?
  • 979 Answers
Was your set moved recently or struck by something. Sounds like the mirror is off center...accordianman
Posted on Feb 15, 2008
  • Michael Borelli Feb 18, 2008
    Either the rack assembly is out of alignment or the mirror is off. Hard to tell which it is from this vantage point. But, a reputable TV shop shop should be able to come out and tell you if it is indeed a mechanical (as I think) or electronic problem. Steel yourself just in case it's the latter. If the set has not suffered a move of some sorts, it's unlikely that something "suddenly shifted" on its own....accordianman
I have a optoma rd65 when on it makes a loud humming noise
You most likely have a failing color wheel. This is a known problem in the RD65. If you search on EBay for an RD50 color wheel it is the same one that goes in the RD65. They are roughly $150 depending on who you purchase from. They can be user replaced if you are handy with tools. The bearings wear out and this causes the humming you are hearing. Optoma RD50 color wheel replacement AVS Home Theater Discussions And...
Sep 23, 2014 | Optoma RD65 65" Rear Projection HDTV
Tv doesnt turn on
Problem with the Optoma DLP 50 in. Rear Projection HDTV-Ready. Television screen remains dark but I get sound.
Apr 02, 2011 | Optoma RD50 50" Rear Projection HDTV-Ready...
My tv a Optoma RD65 made a popping noise, then the screen whent black.
most likely a faulty power cord not sending enough power to the TV or the projectors, for projections, bulbs for plasma, burnt out
Mar 01, 2011 | Optoma RD65 65" Rear Projection HDTV
My daughter put a crack in my protective screen on my 65in. t.v. how much to replace it, and can i do it myself. matt
You can buy the replacement screens from www.searspartsdirect.com Iordered one for mine there. When you order lookfor online coupon codes because I got 20% off of mine when I ordered.
Mar 29, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Mitsubishi 65in
try unpluging for 5 min then try again..this should reset it!
Nov 07, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Screen Noise
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Hitachi 50UX57B 50" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
