Question about GE Profile JGS968 Gas Kitchen Range
GE Profile XL44 Spectra gas oven
Yesterday I put the oven through the self-clean cycle and it seemed to run fine. I pressed self-clean, the display showed 4.00 hours, I hit start and off it went. The display then showed "oven clean/locked door", and the timer ran down from 4.00 hours. When the cycle ended 4 hours later, I had a clean oven, however, the locked door display would not go off. My husband managed to get the door open, but now the oven will not work - bake or broil. When I try to select the bake or broil function, it will not allow me to set the temperature. The range top burners all work. The door opens and closes and appears to latch properly. I set it to run the self-clean cycle again, and the display showed all of the appropriate messages, however the oven door did not lock. I stopped the cycle after about 10 minutes. Probably important: about 1 year ago I had food placed too close to the broiler and the oven caught fire. It was quickly extinguished, but ever since I turn on the oven to bake or broil, the top of the range gets hot - hotter than it used to. It is almost too warm to the touch, as if I burned through the insuluation. I have not put the oven through the self-clean cycle since the oven fire - until yesterday. I have been baking and broiling without incident until yesterday. I have the same problem but no numbers to press help me
    President:
  • 1,314 Answers
Try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: GE Profile XL44 Spectra gas oven
Carol, let me see if I can help you with this. First try killing the power to the oven for 30 seconds and see if the locking mech resets. If nothing changes try this: kill the power for at least ten seconds, power back up,simultaneously press the cooking time, delay start and the number 8 pad. Test should appear in the display. Press and hold the self clean key, this will test the lock motor and cam assy. The display should show 2 on the left (for locked) and change to 3 on the left for unlocked. Travel time of the cam will display a 0 between locked and unlocked. You must hold the self clean key for these changes. This latch mechanism is thermally controlled and sends a message to the main board to lock and unlock during self cleaning. We are just bypassing this with this test. Your temperature sensor may have gone bad during the self cleaning cycle. This is the probe located in the oven cavity. If you know anyone that is handy with a meter, it should ohm out at 1092 ohms at room temp. If this checks out, someone will have to open the top and check the lock motor and cam. Catriver..post back.
Posted on Nov 13, 2006
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
How do you turn off the self cleaning oven when door is locked on the GE Spectra XL44
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hello, I own a GE spectra xl44 self cleaning oven. recently my oven has started to smoke while cooking. I tried to use the self cleaner, however this only set off my fire alarm. I have cleaned all of the...
If you cannot get to clean it fully then open your windows, place a fan in the doorway to encourage the smoke to leave the house and put it on a cleaning cycle.
Use aluminium foil to line the base of the oven rack. That will stop this from happening again when your containers are overfilled.
Jul 23, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGS968 Gas Kitchen Range Logo
608 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
