Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
No picture but sound
If I take the back panel off there is a ceramic 5 fuse right where the power supply comes in the back, it is blown, could that be why there is no pic, I mean could it really be that simple, I tried a lower amp fuse but it did not work,
  • 2 more comments
  • donya Feb 15, 2008
    Thanks Guru, my chassis number is DPTV305F, can you give me the next thing that you would check
    Thanks alot
    wow, you are awesome, the fuse is right next to the incoming power cord and it has a number 1000 stamped on the panel right next to it. Thanks a lot
    everything seemed ok, question, the 5000 coil at the top of all 4 corners where the copper is attached to the plastic, they all seemed to be slightly burnt, is that just the way they are connected or could it be fried? Any other ideas and thanks for everything so far, it is very helpful.
    I dont but thank you
  • Philips Master
  • 8,617 Answers
It could be, but usually something else has caused the fuse to blow. What is the chassis number to your set?
Posted on Feb 14, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Feb 15, 2008
    What is the ceramic fuse number stamped on the board? If you give me that number I can check what circuit that protects. The audio works so that tells me its not going into shutdown. Its probaly just a regulator or resistor thats burning that fuse. So look on the board where the fuse is and give me the location number of that fuse.
  • Sonny Berry
    Ok ceramic fuse 1000 is a safety device it must be replaced with the exact repacement the part number is 2422-093-00035 its rated at 5 amps. Now check transistor no 7807 for being shorted this drives the Horizontal output transistor number 7801 check both of those transistors for being shorted. Let me know what you find. Also check the windings on the line coil 5000 pins 4&3 for resistance and pins 1&2 for the same resistance.
  • Sonny Berry
    Sounds like maybe the line coil is shorted. Do you have the service manual for this set? So you can check the various test points for voltage. let me know if you do or not and I will post a link where you can get the service manual emailed to you.
  • Sonny Berry
    You can get the service manual for your set. Its called Phillip/magnavox DTV305 at the following link. It cost 10.99 and they will email it rigt out to you. They also offer free unlimited support with the service manual to help diagnose and obtain parts. I am one of their senior support techs.
    http://servicemanuals.vstore.ca/
Dynex 26 inch flat screen sound no picture ceramic fuses blown where can I find these
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Fuses can be bought from most of the electronic spare part shops. But, before replacing the fuse, you should check out the cause for the blown off the present fuse, and should rectify it; otherwise, replacing a new fuse at this condition might make problem more complicated.
Jul 30, 2014 | Televison & Video
No Image displayed
If you get no sound but the hum, there is a problem on the power supply panel inside this TV set. The only way to repair this set would be to replace the power supply panel. But before you condemn the power supply panel, open the set and disconnect the back-lite inverter supply and make sure that is not loading down the TV sets power supply. You would not see a picture if you disconnected the inverter circuit, but the sound should come on. Good Luck
Jun 30, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Where can i buy the ceramic fuse for my toshiba flat screen?
That model uses a e.t8ah250vp fuse and they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=316
The fuse is located inside on the power supply board.
Mar 27, 2013 | Toshiba 40E200U 40-Inch 1080p LCD HDTV
Samsung ft-p5084 plaza tv went blank. No power at all.
If that fuse is blown chances are its because the Power supply has developed a short. The power supply will need replacement. You can easially install a power supply yourself just a few screws and couple of wire sockets and the old board pops right out. You can get the power boards from www.tvcircuitboards.com
Feb 09, 2013 | Samsung FPT5084 50 in. Plasma HDTV
MY VIORE PDP42V18HA HAS NO PICTURE ONLY SOUND 1 BLOWN T4 FUSE ON VIDEO BOARD CANT FIND A CERAMIC FUSE TO BUY
it is the y-sustain board that has a blown fuse.. it is problably the one on the left. by replacing the fuse wont solve the issue, you need to replace the whole board.
Dec 04, 2010 | Toymax Viore 42 in. Plasma TV
How to change the fuse on Kitchen Aid model KEMS308SBL02 combination oven and microwave. The oven door locked after a power outage this week and now the oven won't come on.
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Dec 04, 2010 | Ovens
Televisin does not even show red power light
sound like you might have blown a fuse, or the power supply board is bad. if you can take the back off of the unit and check the fuse it is located right where the power comes into the unit, if that is good look at the power supply board and look at the caps in particular and see if they are bulged out like in the picture below, replace them and you will be all set...
Apr 25, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
LG 42PX4MVH PLASMA TV - Sound but no picture.
You need the ysus board. This is a very common problem with LG's. If it is coming up with the fuse removed you are essentially removing the short from the power supply so that it can come up and deliver other voltages for sound and all. Check out encompassparts.com if you are going to try to repair this yourself. Thanks
Oct 24, 2009 | LG 42PX5D 42 in. Plasma HDTV
Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Jun 08, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Instantly blows the 5 amp fuse next to the power cord plug.
You have a short in the power supply. Look at the regulator and or rectifier diodes. These are all on th primary side of the SMPS (switched mode power supply) the secondary side if shorted shouldn't cause a blown fuse at all.
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
