Question about Maytag MER5770 Electric Kitchen Range
Cast iron pans
My glass top stove came with my new house and unfortanetly I don't have the owners manual. Can I use cast iron on my glass top stove.
  • Anonymous May 03, 2008
    Please help, I used a cast iron skillet on my ceramic top, I too, did not have a booklet on my stove. (used). How do I get the marks off my top... I have tryed cleaner for ceramic tops but this has not helped!!!
  • 5,911 Answers
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Posted on Feb 16, 2008
I have been using cast iron on my ceran stove top for 3 years with no problems. I am very carefull with with the cookware.
Posted on Aug 27, 2008
We have a Thermador glass ceramic cook stove Model CET. Can we use a copper infused ceramic skillet? Thanks
I have a glass ceramic top on my Jenn Air and I use one of those new skillets on it all the time, so, yes. It does seem to heat up a little slower than my cast iron skillets, but I've encountered no problems.
Jan 19, 2018 | Thermador Kitchen Ranges
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
How to clean cast iron both pots and pans
Don't..... just rinse with hot water and dry them, the blackening is otherwise known as "seasoning" and protects it from rusting, left to soak or washing with soapy water will rust the cast iron...... if this happens you need to remove as much rust as possible by scrubbing with salt and a cut (half) potato, then wiping with vegetable oil and "seasoning" in a hot oven (do this a few times, the oil will evaporate and bake-on a protective film) think of the edges of your favourite roasting pan....... well used/cared for cast iron will almost certainly look totally black.
Jun 24, 2014 | Lodge Cast Iron Chef John Folses Cast Iron...
How should I store my cast iron skillet?
Ensuring that a Cast Iron Skillet stay "Rust Free" is to keep it "Seasoned". Wash with little soap and hot running water. Then pat dry... then onto the stove top it goes for 2-3 minutes for complete drying. Have a paper towel with "some, not a lot" of shortening or vegetable oil on it, ready. Once the 2-3 minutes on the stove top is complete, Keep the stove on... rub your oiled paper towel, all over the warmed up pan, then take a dry paper towel, and wipe evenly - removing excess oil. Place on the stove top once more before storing away, for about another 2 minutes.
Store with the lid and place another dry paper towel inside the pan, while storing.
Do this, and your cast iron cookware will outlive you!
Jan 16, 2013 | Home
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Glass top range cookware
Here's the recommended cookware for glass top ranges:
Aluminum and Copper - have good heating characteristics, but may leave metal transfer marks on the glass.
Stainless - may take longer to heat and may not heat as evenly (some stainless has a copper liner to aid in heat transfer). More resistant to leaving metal transfer marks.
Baked Enamel - great heating characteristics, provides uniform heating and resists marks on glass surface.
Cast Iron - NOT recommended due to the weight of the metal. Can cause potential cracks or breakage.
Now, any reference to metal transfer marks are merely disclaimers from most manufacturers that the potential exists that the cookware could leave marks on the stove surface. Using a good cook-top cleaning product after the surface cools will aid in removing any of these marks. This does not mean this cookware should not be used.
All cookware used on glass cook-tops should have flat bottoms. There should be no ridges, grooves, or warping. This creates an uneven heat transfer between the pan and surface and can potentially cause the glass to break. Most manufacturers will not honor a warranty where it can be determined that the consumer used the wrong cookware.
Make sure you wipe up any spills on the stove surface that contains sugars or milk. These ingredients (if allowed to burn on the surface and are not cleaned up) will eventually cause damage to the glass surface by either removing the finish or leaving pits and cracks. Wipe up all spills AFTER the surface has been allowed to cool using a non-abrasive cleaning rag or sponge. The green scrubbing pads are considered non-abrasive and CAN be used. DO NOT use steel wool or SOS pads! A small straight blade razor can be used to remove stubborn items by gently scraping in one direction. I don't believe you can use any cleaning product that contains ammonia either.
All of this information can be found in the owners manual that came with the appliance. If you don't have a user/owner's manual, post back with your model number and I'll see if I can locate it for you. I hope this helps you.
Apr 17, 2008 | Kitchen Ranges
Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Jan 03, 2008 | Kitchen Ranges
Maytag MER5770 Electric Kitchen Range Logo
798 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
