Question about Panasonic KX-TG6074B Phone
Very loud volume when turning on phone
When turning on the phone, you get very loud volume and a echo.
    President:
  • 1,017 Answers
Put it on Silent mode before you turn it off.
Posted on Feb 14, 2008
  • Raysagem
    Raysagem Feb 14, 2008
    Sorry, on reflection, you may not have that facility on that model.
Why does my phone have an echo?
Some phones will echo if the volume is turned up to high. Try turning the volume down a couple of bars and see if that helps.
May 28, 2014 | T-Mobile Concord
How do i hard rest my phone
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm. If those steps don't work perform the following steps:
  6. Turn the power off. If your Kyocera Echo is frozen, pull the battery out and reinsert it
  7. Hold the Volume Down button
  8. Press and hold the Power button until the device turns on
  9. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  10. Select Clear Storage by pressing the Volume Down button
  11. Press and release the Power button
  12. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
Dec 24, 2013 | Kyocera Echo Smartphone Sprint
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
How do you turn the volume down on a GN9330
check themanual and if ur too independant and threw it away print out a copy online
Apr 19, 2010 | Jabra GN9330 Wireless Headset
Our new 6.0 Caller ID phones have an echo. Can you suggest a remedy? John Chalk johnchalk@hotmail.com
as per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know"
Feb 11, 2010 | Panasonic (KX-TG1032S) Phone
Echo on my end when someone calls! Please help! Thanks!
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
What do you recommend to stop phone echoing? I own an AT&T Dect 6.0 cordless. It echos no matter where you are in the house.
Echo is usually caused by the mouthpiece picking up sound from an overly loud earpiece.
if there is a way of turning the volume down try that, if not the only other possible thing to try would be to dampen the volume from the earpiece using a small piece of tape or similar.
Jul 07, 2009 | AT&T 2462 Cordless Phone
Echo problem
Germans and americans dont mix,,,dump the car,,
Feb 10, 2009 | Apple iPhone 3G
Speaker phone volume keeps going loud and quiet
Did the location change, a Echo from a wall or vibration from the table. It is a one way sound, someone talks and you hear. As soon as you talk it cuts out the speaker even if they are still talking and it transmitts what you say. So any noise in the room could trigger the the transmit mode even an echo from the sound being turned up too loud. The mike is on the bottom of the base and can pick up table vibration and send it into transmit mode. So the person talking cuts in and out.
AL
Jan 15, 2009 | Sony SPP IM977 Cordless Phone
New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Nov 04, 2008 | GN Netcom GN 9120 Professional Headset
Panasonic KX-TG6074B Phone Logo
144 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
