I have a toshiba laptop satellite L25 - S121 when I turn the computer on it says PXE-E61: media test failure, check cable, PXE-M0F: exiting PXE ROM. then it finally says Operating System not found.
I have tried to use the recovery and applications /drivers DVD but nothing happens.
Is there anyone that can help me?
Comments:
Feb 14, 2008
- it will not let me enter anything, so I do not think that will work
Please help my PC gave this message when I switched it on Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test Failure, check cable
PXE-MOF: Exiting Intel PXE Rom Operating System not found
What is wrong and how do I fix this -   kvincell
Dec 23, 2008
-   i added memory and replaced the hard drive. I went into the bios and it recognizes the new memory and hd. I also changed the boot order to: cd / hd / external device / network. This did not help. Does this mean it is the motherboard? Any other suggestions? Thanks...
-   njsmom
Hey you try this.
Enter into BIOS, Disable SATA Support, if problem persists, change your Hard Disk, that is crashed. I had the same problem last month.
Gateway MP6954 laptop. No power. All power cords checked: clean and tight. With battery in: push...
(More)
Gateway MP6954 laptop. No power. All power cords checked: clean and tight. With battery in: push power button and get red light blink on front; without battery (just AC): push power button and get nothing...not even red light blink on front!
One day i turned it on and it went to a list of things to do, safe mode safe mode with networking...
(More)
One day i turned it on and it went to a list of things to do, safe mode safe mode with networking etc. And it only works when i press safe mode with networking. My laptop has no cd drive or floppy disk drive or anything so i was wondering on how i could fix it, or re-install windows the easiest way without a cd. And i have tried system restore and other things many times but nothing has worked. I can go onto safe mode with networking and everything will work just fine except webcam, sound, etc. thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
