Question about Indesit W 123 Front Load Washer
Washing machine the drum in my washing machine is loose and when spinning it bangs around and rubs against the door seal causing smoke to come out when i open the door,can i fix it myself or is a new washer the only answer?
  • 20 Answers
You can try and fix it your self, it sounds like to me the main drum bearing at the back of the drum has gone bad, it all depends if the parts are available and you are up to tearing the unit down to fix it.
Posted on Feb 14, 2008
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Banging when spinning and rubber smell
if the basket wabbles like crazy, could have a cracked spider that holds the basket
Mar 01, 2014 | Washing Machines
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
LG wm2016cw smells when spinning fast. I opened the top but do not visually see any damage or smell it. When I open the door, I can smell something was rubbing. Took off the door gasket and it seems fine....
It sounds as though the drum may have dropped slightly and is rubbing against the seal. This normally occurs when either the top springs have stretched slightly (visually it's not noticeable) or the bearings are worn. Hopefully it's the former, as the springs are replaceable at little cost and can be done as a DIY project. The best way to see if it is the drum, is to close the door and look through the door window. The drum should appear central to the window. There will be online guides on how to change your particular model springs, as they are all slightly different. The only other possibility is that the drive belt at the rear of the machine is wearing out, or rubbing against something.
Dec 04, 2017 | Washing Machines
I have a GE Front Loader. Model# GHDVH670H1GG. The tumbler works until water is required to be drained. At that time, the tumbler is trying to tumble for rinse, but, the water is not being drained and not...
On my machine the pump filter was clogged preventing the water from draining out of the machine properly. This would leave the clothes soaked in water as the machine tried to spin, the extra weight caused the drum to rub against the door seal while spinning, causing the burnt rubber smoke! I removed the 3 screws on the lower fron panel of the machine and opened the drain ( make sure you have a pan or bucket to catch the water! ) cleaned the fliter and put everything back. Works like new again. Good luck.
Sep 22, 2010 | GE WSXH208A Front Load Washer
My machine bangs on a full it the drum bearing?its a do you replace bearing or fix this problem.
If it bangs it doesn't necessarily mean it is the bearing that is gone. It could just be a imbalance on the load inside. To check if bearings are gone open the door and at the rear of the door seal nearest the inner drum use your fingers to hold down the outer drum, will be at rear edge of seal, now use your other hand at the top pressing the inner drum edge and now press down on outer drum and up on inner drum. If bearings are gone her will be a lot of movement between the two. If no real evident movement then you can feel pretty sure it's not the bearings. Check suspension for signs of wear and check for loose weight block, also check for loose components inside the shell that may be hitting the outer drum. Could also be that the machine is unbalanced if the feet adjusters are not properly adjusted to level the machine correctly.
Feb 07, 2010 | Washing Machines
During a spin cycle what would cause the basket to be out of balance on every washload, even when there is not a balance issue. Basket acts loose and bangs against inside of machine
sounds like your bearings are excessively worn, open the machine door and hold the drum (stainless steel bit) try to lift this up if it moves freely without the tub moving (outer bit usually plastic or steel without holes) your bearings are gone. or the drum has broken off the wields that hold it to the shaft.
its sometimes cheaper to buy a new machine than repair the bearings and if the drum is loose it will eventually break something inside.
Jul 22, 2009 | GE Washing Machines
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
Indesit W 123 Front Load Washer Logo
288 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
