Question about HP DeskJet F380 All-In-One Printer
Power problem suddenly, for no apparent reason, my fairly new hp f380 will no longer turn on when i push the power button....why??
  • 1 more comment
  • bethbee Feb 21, 2008
    I have the same problem did you find an answer?
  • Itbroke Feb 25, 2008
    I had a brief (2 sec.) power outage this morning. When I went to use my F380
    this afternoon it would not power up.
    I un-plugged it from the wall and waited 10-15 minutes. I plugged it back in and now its back to normal.
    It must have some kind of protection circuit built in or something.
  • Anonymous Feb 27, 2008
    do not on power
  • 12 Answers
The Printer unable to turn on could be of two reasons.
(1) Connect the Printer directly to the wall outlet instead of connecting through the power surge protector (If connected through surge protector).
(2) Check whether the Power adapter is getting warmed up after connecting to a particular wall outlet.
(3) Try connecting the printer to any other wall outlet and check for the results.
Hope this information would help you in this regard.
With regards,
Ashesburn.
Posted on Feb 25, 2008
HP Pavilion a6602f suddenly stopped working for no apparent reason.
Hello there, I am the Expert that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Debdeb_64.
The power supply could be ok, this little green light that you see on the rear of the tower case is likely to be the Ethernet/Network connection.
Possible reasons for failure are as follows:
It could be a loose connection at the 24Pin or Processor 4Pin power connector.
A damaged power supply, is possible.
A faulty power on switch.
A dead mainboard.
A loose connection.
I have published a few guides that should help you in this regard, they are entitled:
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
and most importantly My Computer is not turning on!!! Is it dead!!! No POST!!!
Do contact a computer technician to test components if need be.
Take care!
Feb 03, 2012 | Computers & Internet
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
I just refilled my ink cartridges and for some reason the printer still flashes no ink, any ideas?
  1. Press the On (c00636182.gif ) button to turn off the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Connect the power cord to the back of the unit.
  4. Press the On (c00636182.gif ) button to turn on the unit.and hold it down 10 se
this are the usual procedure..some do it by actually power off ..disconnect power cord..hold down the button ..and connect power cord with the button pressed..and after it powers..release the button ..try it both way s..the issue is that you probably used refilled cartridges and it needs to reset the counters..
Jun 02, 2010 | HP DeskJet F380 All-In-One Printer
Daenyx dvd player suddenly won't turn on....no apparent reason
I have a daenyx dv-833b dvd player. the power button does not turn on when pressed. how can this be resolved?
Mar 22, 2009 | Televison & Video
HP Deskjet all in one printer F380, won't feed paper through when
if there is a button beside the red flashing led just push it it will then load the paper could be it is not sensing the paper or perhaps the papaer is not pushed in far enough i have got an old hp and it does it all the time
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
F380 not printing on mac reason: hp aio print2 pde plug-in
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | HP DeskJet F380 All-In-One Printer
GE Profile built in dishwasher problem
Try cutting the breaker off for 5 min, This will reset the control.
Mar 14, 2008 | GE Profile PDW8400J Built-in Dishwasher
Resume Button
ok..well..not knowing what caused the first problem, you might need new drivers(which fracture for little apparent reason).
get em here
Mar 13, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Power doesn't turn on
NO! Do not buy a new motherboard or pc without checking some things.
First, is the green light you say is blinking on the Power Supply itself?
If it is, then the power supply is dead. A blinking light on a PSU means that it can no longer hold a charge and needs to be replaced. Get a new one and pop it in.
Mar 10, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
Koala babe, narrow the problem. Is there any sign of power presence in the unit. Could be just a power issue. You did not mention any lights indication on your front panel.
Good luck.
Jan 22, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
HP DeskJet F380 All-In-One Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
