Question about Krups Palatino 905-42 Espresso Machine
Krups 905-42 Palatino
My coffee maker is leaking water (lots of it) from the boiler (the water goes down/out the machine). Already tried with a sealant around the boiler but water keeps coming out. I´m not sure if the sealant I used is the correct one just know it can take 1500ºC but I think it is not water resistant. I can try another one being water resistant but also don´t know if it is secure to seal it hard. Can anyone help me please? Thanks
2 Suggested Answers
  • 2039 Answers
SOURCE: leaking from boiler
normally you suppose to change the seal kit if it old it very hard to open bolt jammed in calcium unless our very handy if you go to a shop nobody gonna whatto do it they gonna sell you a new boiller the only thing that might do it you clean the outside of boiller very good use epoxy glue the one that drys in 1 minute any hardware store should have that thanks for using fixya pierre
Posted on Feb 14, 2008
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Krups xp 4050 leaks water under unit when sitting on counter
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 13, 2010 | Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Burned out circuit board - how do I get a
Krups coffee makers are supported by many appliance repair shops. If you get the part from them and it doesn't work you are SOL. If you let them fix it and pay more it will be their worry.
Oct 12, 2009 | Krups Palatino 905-42 Espresso Machine
Need new steam tube
Try this: http://www.smallappliance.com/product.asp?cur=USD&sid=18954&gid=18960&mid=15&pid=7108&prdCls=P&shopBy=Brand
Jun 16, 2008 | Krups Palatino 905-42 Espresso Machine
2 problems: not enough hot water, and where the rubberized tube goes
It's my opinion that the tube goes in the boiler so that when the water boils, the steam will push the water up the tube and to the brew head. Without the tube, you will just get steam through the grounds.
Mar 10, 2008 | Krups Bravo Plus 872 Espresso Machine
Knob not working
Try crupsusa.com
They can steer you to the nearest espresso repair.
Mar 04, 2008 | Krups Palatino 905-42 Espresso Machine
Leaking from boiler
Feb 14, 2008 | Krups Palatino 905-42 Espresso Machine
Krups Palatino 905-42 Espresso Machine Logo
89 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
