Question about Krups Palatino 905-42 Espresso Machine
Leaking from boiler
My coffee maker is leaking water (lots of it) from the boiler (the water goes down/out the machine). Already tried with a sealant around the boiler but water keeps coming out. I´m not sure if the sealant I used is the correct one just know it can take 1500ºC but I think it is not water resistant. I can try another one being water resistant but also don´t know if it is secure to seal it hard. Can anyone help me please? Thanks
  • 2 more comments
  • MMGms Feb 15, 2008
    Thanks for your help Pierre. Tried the epoxy glue (you are correct, we must be very handy) but after all that work the water is leaking from the screws! I´m not able to take screws out because they are really really stuck. Don´t know what else to do. Thanks. MMGms
  • spot22 May 10, 2008
    Water started leaking from my Saeco Vienna. I called several repair places, all advise to change the boiler. Boiler is sold for $125, labor varies up to $150. Any other suggestions? The new machine is $400, Saeco offers $100 discount for trade-in old one. Is it worth to repair?
  • Anonymous Jun 16, 2008
    valve opens when switched on and water comes out of it at high pressure from the boiler.
  • martha99 Feb 21, 2009
    We have the same problem and would like to purchase a replacement heater. Is it available?
  • 2,039 Answers
Normally you suppose to change the seal kit if it old it very hard to open bolt jammed in calcium unless our very handy if you go to a shop nobody gonna whatto do it they gonna sell you a new boiller the only thing that might do it you clean the outside of boiller very good use epoxy glue the one that drys in 1 minute any hardware store should have that thanks for using fixya pierre
Posted on Feb 14, 2008
  • pierre laplante Feb 17, 2008
    i had the same problem got the bolt off had to drill retread everything unless you got the equipement forget it or try to seal off everything with epoxy or im sorry to say you gonna have to buy a boiller good luck pierre
There's is water leaking inside my Saeco Magic Deluxe superautomatic espresso machine. Is it a bad boiler?
i had a similar problem and found it was just a gasket on the boiler that wasnt sealing properly.i used JB WELD to repair mine.check all connections and/or gaskets for signs of leaks or possibly a broken gasket mating surface.
Dec 30, 2011 | Saeco Magic De Luxe Espresso Machine
When pulling coffee by opening valve, water leaks from spindle. Safety valve is leaking?
in the system you have 2 safety valves. one for tank other for coffee boiler. the coffee boiler safety valve should be set at 12 bar. if safety valve of boiler is leaking try resetting or changing rubber than setting.
ps: do not touch the tank safety valve, only change it with new, tested and sealed one.
Feb 09, 2011 | La Pavoni CUA001R Cuadra Espresso Machine
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Coffee doesnt flow but water gathers in the drip pan instead.
Hi Your problem is probably the boiler leaking. Its located just above the drip tray in the center of the machine. When it starts leaking it goes into the drip tray or on the counter top. If you can remove the top, you can see if the boiler is leaking. There will be a white line between the 2 halves of the boiler.
Feb 09, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco stratos coffee maker started to leak inside the machine. I have cleaned the unit recently. It has been working flawlessly for the last 3 years, and I have brewed about 3600 cups. The water leakage...
HI
There are a lot of things that can cause the machine to leak.
You could have a fitting or tube that is broken.
You boiler could be leaking and needs to be replaced.
You could have a hose connection that has come loose.
You could have a bad seal at a connection.
Until you get inside you will not know? You might want to have someone look at it for you.
Scale is one of the major causes for machines to start leaking. Make sure that your water hardness is set on 4, so you descale more often than not enough, to prevent leakage in the boiler.
Nov 07, 2009 | Saeco Stratos Coffee Maker, Espresso...
Saeco Magic Deluxe water leak
Hi Boilers leaking are usually a sign of not descaling enough. It is not recommended to take apart your machine unless you have knowledge in electronic repair. There are a lot of wires and hoses.
Once the boiler starts leaking it needs to be replaced. email me for directions since it won't fit on this page.
Mar 04, 2009 | Saeco Magic De Luxe Espresso Machine
Pump keeps running and excess water goes into the cup tray
check the level probe on side of boiler may not be facing down as it should or need to be replaced.
Nov 16, 2008 | Nuova Simonelli Oscar Coffee Maker,...
When I make coffee, there is water leaking probably from the drain, even after I changed the seals with new ones.
there are several places where this machine can leak. Check all the connecting hoses from the boiler , they are just clicked in by holder pins.
Even the seal in the boiler itself can be worn.
Follow this link for diagram and parts ( unfortunately in spanish sorry for that)
SAECO VIENNA SA
Oh by the way the seal on the spout which goes into your brew group can be damaged too. Check that first
Apr 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
Krups Palatino 905-42 Espresso Machine Logo
266 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
