Question about Tvone TV-207 Television
GE TV set has picture but no sound model GE09GP106
Greetings:
My TV set has picture but no sound. Will appreciate you advise me possible cause(s)
Thanks
  • mandino Feb 15, 2008
    Greetings:
    With further reference to my previous posting " my tv has picture but no sound", I pulled back the main board to inspect the internal speaker when I return it back to the original position, am not getting picture, only a very fine horizontal line in the middle of the screen.
    Will appreciate your solution to this new problem.
    Thanks...
  • Anonymous Jan 21, 2009
    I have an old ge televsion and also verizon fios and now I have no volume on the tv Called verizon and of course they were no help at all. I am hoping someone can give me a solution to this problem. Not much use if you only have a picture and no sound thanks Carole
Verizon- picture but no sound
Posted on Mar 14, 2008
    Sergeant:
    Champion:
  • 346 Answers
If you have a schematic diagram you need to look for the mute transistor and replace it, if you only have technical experience
Posted on Mar 10, 2008
  • 2,130 Answers
If the set has a headphone jack, have you tried plugging in a set of headphones?
If the sound works on the headphones, you may have a bad internal speaker.
If you don't get any sound in the headphones, the audio amplifier may have failed as it drives both the headphone jack & speaker.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 14, 2008
  • SHARCNET-USA
    SHARCNET-USA Feb 15, 2008
    I need to know whether there was a headphone jack and if there was sound there before you first opened the set.
    If a speaker is bad, you will not be able to tell by just a visual inspection, unless the paper cone is torn. If a spealer is bad, the voice coil will be open. You can only determine this with an ohmmeter.
    The horizonal line is cause by a lack of vertical deflection on the CRT. It sounds like you may have accidently disconnected a plug or cable while you were moving the motherboard.
    Hopefully you did this with the power off.
    - Jim
RCA 42" Plasma 720p 600Hz HDTV black screen model # 42pa30rq I have sound npicture please advise thank you
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 11, 2014 | RCA 42PA30RQ 42 Class Plasma TV - 1024 x...
I have a GE TV model: 27GT271 and no sound
Possible cause of the problrm is bad/poor solder on the grounds for the tuner circuit shield an the bottom (solder side) of the circuit board. Grounds need a wire jumper from point to point. This was a common problem for those sets and ocassionally it would take out the eeprom chip with it. (Various other problems were shrinking picture/fuzzy picture and intermitt. power)
May 14, 2009 | GE 27GT271 TV
Sound but no picture
The first thing to check is the connections to your source. They can easily become loose and/or corroded over time.
Feb 25, 2009 | GE 46GW945 46" Rear Projection Television
SOUND NO PICTURE
I simply opened the TV set, and surprisingly found condensation on some of the electronic panels. I pulled out my blowdryer and aired them on low....reassembled the tv, and then turned it back on. Boy, was I surprised that it worked! That's how I got my picture back. Works fine now. Thanks.
Jan 04, 2009 | GE 13TVR70 13 in. Combo
Dead polaroid model 2700 visionquest tv
Your power supply has failed; have it replaced
Jan 16, 2018 | Televison & Video
HAS SOUND,NO PICTURE?
YOU'VE LOST VERTCAL DEFLECTION---THIS COULD BE SOME PARTS IN THE VERTICAL SECTION BAD,,LOST A VOLTAGE GOING TO THE CIRCUIT OR WORST CASE ----FLUID FROM THE PICTURE TUBES HAVE LEAKED ON THE CIR BOARDS CAUSING THIS PROBLEM---NEED TECH FOR THIS ONE!!!!!!!!!!!
Sep 15, 2007 | GE 46GW945 46" Rear Projection Television
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
Picture turns to lines
sounds like an intermittant connection on the convergence IC'S or the vertical sweep curcuit. I would advise that you seek to have this fixed as soon as possible as tapping on the side can and will cause other problems in the set.. I would also advise that if your not an experienced tech take the set in to a repair shop. Good Luck
May 19, 2006 | Toshiba 57H83 TV
Tv problem
Does it like tune and detune and then retunes back to a pic all by itself??? sounds like the typical problems rca/ge sets mostly have in common with bad tuner grounds.. you must open the set remove the bottom tuner sheild and resolder all the grounds along with the little post that hold on the sheild to the tuner. Now this is not a job for the hobbiest!!! You can cause a small solder splash and ruin the set for life cause you may think that you got out that little solder splash BUt unaware to you you also have taken out some very tiny parts that look like a pieces of dirt that are surface mount resistors and capacitors.
Mar 22, 2006 | GE 27GT619 27" TV
Televison & Video Logo
434 people viewed this question
Top Tvone Televison & Video Experts
Jaime Hernandez
Falling star
Jeffrey
Jeffrey
Are you a Tvone Televison and Video Expert? Answer questions, earn points and help others
