Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Dead Reddy heater 170T
I changed the pump accuater about a month ago, as it was shattered. I also replaced the ignitor and all filters. It ran fine for like a week, now when I switch it on nothing happens except for the switch lights up. These reddy heaters are kiling me!! Can anyone help?
  • pdub125 Feb 14, 2008
    Everything has been cleaned thourougly. The unit does nothing. No codes, no temp, just the power switch light.
  • 20 Answers
When chaning the filters, did you clean out the flame chamber, a lot of carbon and suot will build up inside and cause the unit not lite.
Posted on Feb 14, 2008
Reddy heater 170T- terrible fumes-fuel pressure problem
Are you sure there is not water in the tank? Fuel pressure should almost never need adjusted.
Jan 08, 2014 | Reddy Heating & Cooling
Reddy heater 170T ignitor (#PP200) not glowing at start up.
if its the ceramic glow rod they brake easy and cost 40.00 plus some times usually broke down next to the base ceramic only ever had one power supply go on me but hard to dignose
Dec 09, 2013 | Heating & Cooling
Reddy Heater 170T works fine with the cover off but will not ignite with the cover on.
First, heaters with Hot Surface Ignitor technology MUST have the air pump pressure set to factory specs. The onboard computer will not allow any deviation. Proper fuel delivery depends on it.
Now, if the pump pressure is correct, there are no leaks between the pump and the nozzle and no vac leaks on the fuel line, the 90% of the time the problem is a worn nozzle. Desa recommended annual replacement of the nozzle simply because of the wear factor.
More troubleshooting tips
Oct 31, 2011 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
Not getting fuel after air and fuel filter maintenance.
If the maintenance procedure included anything that required you to dis-assemble the air pump then you must simply re-set the pump pressure in order for fuel to be pumped into the combustion chamber. . It's an easy procedure. Instructions for setting the pump pressure
Feb 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't light
Are the ignitors intact? In other words, does the element make a loop back to the ceramic portion. The purpose of the LED is to notify the user of a defective ignitor. The other possibility is a bad control board.
If the ignitor is intact, but no power coming from the board (ignitor only glows for 5 seconds), then the board is bad or the fuse is blown. You might want to test the photocell while you are at it.
You will need to locate the correct model numbers to order the correct parts. "170T" & "125T" are only part of the correct model designation.
Post back if you have further questions.
Oct 23, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't light
My suggestion would be to clean the nozzle and the fuel lines. Make sure after they are clean you have a good mist from the nozzle.
Mar 18, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
1,087 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
