Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Is there an option for AUX or Auxilary input anywhere on the head?
Try switching the input source through all possible settings while playing the ipod and ensuring the volume is on, to see if it plays.
hi try this their is a button on remote thats say AV or it may b input or it may b a square with an arrow pointing into the square symbol . let u know how u go .
You can try starting the music on your computer before trying to change the input on the receiver, maybe it needs to recognize some input before it will change if this doesn't help double check your connections & settings ?
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3. This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Hello gerrydav,
What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it.
I look forward to your posts.
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
