Question about Car Audio & Video
Bridgeable vs not bridgeable
What is the difference? which should I get and why?
All amplifiers are bridgeable. The bridge setting is for driving a large speaker by using the power output of 2 or more channels. The power will be summed if a bridge is made.
For example, if you have a 800W, 4 channel power stage, you can connect 2 component speakers in the channels 1 and 2 and bridge the channel 3 with the 4 to drive a subwoofer.
Posted on Feb 15, 2008
What's the different between star c3 VS ordinary quality and star c3 VS super mb star
is the super mb star ? If so, the star c3 will more professional than it, just my opinion.
Apr 09, 2013 | BMW Cars & Trucks
How do i bridge all 4 channels on the jensen 400 watt 4 channel lxa amp ?
  • This amp is not "bridgeable" at all. You will either blow the front end or blow the low end voice coil in your sub.
Regards, Tony
May 24, 2011 | Jensen LXA400 Car Audio Amplifier
How 2 bridage an alpine n a kenwood togethes
you cannot bridge them together. if they are bridgeable, you can bridge one amp to one speaker and the other amp to the other speaker. make sure not to go lower than the required ohm for each amp. also, you probably will get a different output wattage for each amp.
Nov 02, 2009 | Car Audio & Video
Not enough Amp?
You should still get sound even with small amps but it would be rather weak. Check first the source of the signal. Test with different sources to be sure. Check for loose connections.
Oct 02, 2009 | Rockford Fosgate Punch 400W Class AB...
Titanium 800.1
It's a mono block so define bridgeable? It is only a "ONE" channel amp.
Jun 19, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
Bridge a not bridgeable amp
It will probably blow a fuse or blow up completely.
When the output stages ar not lifted from ground
as is the case in a bridgeable amp bridging cannot
be done.
Jan 12, 2008 | Performance Teknique ICBM-782 Car Audio...
Boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Dec 05, 2007 | Boss C150 Car Audio Amplifier
Gemini P601
the gemini p-601 is not bridgeable. you can select either speaker pair a, speaker pair b, or both pairs, but you can not bridge it without potentially damaging the unit.
Oct 27, 2007 | Philips GEMINI P-601 Fan CooledStereo...
Car Audio & Video Logo
505 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
