Question about Eten Glofiish X500 GPS Pocket PC
Dead Glofiish x500
I purchased a new Glofiish X500, which worked perfectly for about 24 hours. Then I entered the numbers on a scratch card to buy airtime. The PDA locked up. I tried to reset it, with no success. Took the battery out and reinstalled it, without success. I put it on charge once again and the green light on it comes on and stays on. If I try to reset it the red lights keeps blinking, but the screen remains blank. Is there any hope for this????
  • 4 more comments
  • Alice White
    Alice White Feb 14, 2008
    I tried...when plugged into the USB port the green light is on, when you push the on button, the red light flashes...
    Kind of discouraging.
  • Alice White
    Problem is I bought it from US, and had it sent to Zambia where I am living. The nearest place that "might???" be able to fix it is 700 miles away.
  • Alice White
    The other problem is that it came with Spanish installed...no English including the PDA, the CD and the instruction leaflet. Any idea where I could find that info???
  • Alice White
    I would like to be able to get help on the internet, and not have to send it overseas either to US or China for repairs...
  • Alice White
    Alice White Feb 15, 2008
    Anybody know where I could download the software for the Glofiish x500 in English, the CD I was sent is only in Spanish, and the preinstalled stuff on the Glofiish is all in Spanish also. Maybe someone out there wants to buy a sick Spanish Glofiish????
  • Alice White
    What is a Lil Sync® Duo Adapter? An USB cable with a connection came with the PDA, is this what you mean?
Posted by
coolguy008:"You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds."
Ignore this comment, with the 150mA that the USB port delivers, it's impossible to make the battery explode.
The battery has internal charging circuits that prevents any abnormal operation avoiding "explosions", "Overcharging" and such things.
20 seconds isn't sufficient time to recharge the battery enough to make the pone turn ON.
You can left the battery connected to the USB port for 2 or 3 hours to recharge it completely.
Posted on Feb 15, 2008
    Novelist:
  • 123 Answers
Try removing and replacing the battery, or try a hard reset if you can
Holding down the Power button and then, simultaneously pressing in the reset button. Once the screen changes, press and hold the End Call (red phone) button. Keep holding until the first of the two questions comes up. Release the End Call button, then answer 'Yes' to both questions. This will completely remove everything on your system and restore it to 'out of the box' condition.
Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 14, 2008
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 14, 2008
    There are three different ways to use your Lil’ Sync® DUO Adapter in conjunction with your accessories (device, bluetooth headset, etc.) and/or your Lil’ Sync® Pro Cable.
    Use only the Lil’ Sync® Pro Cable when charging your E-TEN glofiish X500 from a laptop or PC. The Lil’ Sync® Pro Cable will sync and charge your E-TEN glofiish X500 simultaneously. If your battery is completely dead, you can use the Lil’ Sync® DUO Adapter with your laptop or PC to start the charge. Once your battery has reached at least 30%, you can unplug the Lil’ Sync® DUO Adapter and use only the Lil’ Sync® Pro Cable to fully charge your E-TEN glofiish X500 from a laptop or PC.
    Use your Lil’ Sync® Pro Cable along with your Lil’ Sync® DUO Adapter to charge your E-TEN glofiish X500 from any AC/DC USB power source. Your Lil’ Sync® DUO Adapter may be required to charge your E-TEN glofiish X500 when charging from AC/DC USB power.
    Use your Lil’ Sync® Pro Cable along with your Lil’ Sync® DUO Adapter to charge your E-TEN glofiish X500 and a second accessory, such as a Motorola headset, simultaneously from any AC/DC USB power source.
    Additionally, we have enhanced our original Lil' Sync® Pro by upgrading to USB 2.0, a more robust retracting mechanism, increasing the cable strength and power capacity, and increasing the length by 15 inches.
    Jabra Compatibility: Jabra A210 Bluetooth Adapter, BT150, BT160, BT320s, BT350, BT500, BT500v, BT620s, BT800, JX10 Headsets
    IMPORTANT: The Lil Sync® Duo Adapter DOES NOT sync one E-TEN glofiish X500 while charging another, nor does it allow you to sync two devices simultaneously. The Lil Sync® Duo Adapters are for charging only.
    Good Luck
    here is the link for solving your problem visit
    http://www.mobiletechreview.com/phones/E...
    Good Luck
    Brigadier General:
  • 6,966 Answers
With the indulgence of the other posters. It would seem that you have tried most if not all of the remedies. Perhaps you can try:
1. Clean the battery terminals and the phone's battery contacts;
2. You may need to bend the little pins to put more pressure to its contacts to the battery;
3. Thereafter leave the phone off but charge continuously (preferably overnight).
Although may I also point out that if it is indeed a battery issue, then coolguy008's response would be more applicable. If I may add, his suggestion is designed to wake-up or shock charge the battery.
If your concern has not been corrected after completion of any of the above procedures, you can of course try another/new battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
  • 796 Answers
Hello sir
    Genius:
  • 1,665 Answers
As it is just bought better give it back because is defective and replace it.They regularly have one year Warranty.
Or download manual to get some help for troubleshooting.
http://www.phonedog.com/cell-phone-research/eten-glofiish-x500_user-manual.aspx
  • 552 Answers
 Remove the battery and sim card, plug it to the computer and push the on button.The red light will go off and then the problem is solved.
Put back the sim card and battery, close the cover andit should work correclty again.
Without loosing any data.
Hope it will work for you also.
    Genius:
  • 3,422 Answers
The problem is with your phone sir the cause might be a bug in the firmware which spoilt the phone.I suggest you to take it to the service center and get the new firmware installed from them.
Goodluck..
  • 1 more comment
  • Priya darshan Feb 14, 2008
    Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well enough. It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
    You can fix this, but do so at your own risk.
    You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
    Now, on to the fix
    -Take out the battery.
    -strip
    ****WARNING****
    DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
    ****WARNING****
    -now
    carefully hold the black wire to the negative terminal on the battery
    (it should be noted with a black circle with a - in the middle). Then
    touch the red wire to the positive terminal (it will be noted with a
    red circle with a + in the middle).
    Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone,
    and then plug it into a regular charger. Give it little bit of time, if
    you've done everything correctly the charge light should come on.
    I had to repeat the last step again to get the light to turn on indicating it was charging.
    You
    Just be careful and you'll be fine.
    One
    you get a charge light give it a few minutes in the off position, then
    try powering up the device and keep it plugged in until you get 100%
    charge.
    Good luck,
    here are the contact details.Just give them a call and tell them the same problem as you did here if my solution does not work.If there is an easier way to fix your problem they will tell you on the phone itself.One more thing just give them a mail and they will give you an english manual.
    E-TEN Corp.
    E-TEN Headquarters
    No. 256, Yangguang Street,
    Neihu Chiu,
    Taipei, Taiwan 114, R.O.C.
    TEL:(886)277210000
    FAX:(886)277210123
    E-TEN@etencorp.com
    sir what do you think about my solution?
    Are you satisfied or not??And if you are satisfied then please don't forget to rate me as fixya.
    Thankyou..
    Master:
  • 788 Answers
If it's new then get it replaced should have a warranty.
Transfer my phone number to new phone
If the phone still turns on, transfer all your contacts to us SD card and use the same SD card on ur new phone.
Mar 22, 2013 | ZTE Score X500
I want registrybooster serial number now
I think Ccleaner is better and it's free.
http://www.filehippo.com/download_ccleaner/
If you still want registrybooster,search on
http://4shared.com
Mar 29, 2010 | Eten Glofiish X500 GPS Pocket PC
How to oprate golfish x650
http://www.glofiish.com/download.asp?lang=3
download manual here
Mar 16, 2010 | Eten Glofiish X500 GPS Pocket PC
My x500 freez upon boot
there's a small capacitor on the eten x500 mainboard, very close to the reset button. it's a pull-down capacitor that counts tao-time for entering your unit to bootloader.
I believe this capacitor is broken, and device cannot enter to windows OS and keep the bootloader mode.
you can try to download the ETEN last rom image and try to flash it, maybe it will be the solution for you. but I guess the capacitor in the mainboard could be the real reason. that's from my technician experience..
Aug 29, 2009 | Eten Glofiish X500 GPS Pocket PC
Hbnivn@yahoo.com
Aquy se encuentra el manual y la descarga de software para su Glofiish.
Manual /software /applications
Aug 22, 2008 | Eten Glofiish X500 GPS Pocket PC
Eten Glofish X500
what is the installer of x610 for Computer
Jul 03, 2008 | Eten Glofiish X500 GPS Pocket PC
Glofiish X600
I believed someone had entered too much inccorect passwords so it totally locked. You probably try a Hard Reset to bring the unit back to default setting but you may loose some data in it. To perform hard reset just hold the power button and reset button with your stylus at the same time and push.
Feb 27, 2008 | Eten Glofiish X500 GPS Pocket PC
X500 glofiish
visit www.pdaviet.com
Get a cooked rom, follow the instructions on how to Flash your rom to pdaviet.
I suggest pdaviet x500 version3 (V3)
All you problems will be cured.
Feb 21, 2008 | Eten Glofiish X500 GPS Pocket PC
Eten Glofiish X500 GPS Pocket PC Logo
266 people viewed this question
Top Eten Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Eten Computer and Internet Expert? Answer questions, earn points and help others
