Question about Marantz SR5001
Trying to hook up Apple TV
Have SR5001 with both HDMI inputs assigned.  1 to Blu-Ray, 1 to DSS, Satellite DVR/box.  Therefore I am trying to use component hookups for the video and a digital connection for the audio.  I hooked up the component to the 1st component input on the back and the digital audio to the #1 digital audio input on the back. I then tried to go through the process of assigning the input. I went through the menu system and assigned "Aux1 to "comp 1" but nothing happened when I dialed up that input and tried to test the connection.  Part of the problem is that the manual does not explain the settings for "dig"  "HDMI" and "COMP".  The "HDMI" choices in the Input menu are self-explanatory, there are 2 inputs so I can choose 1 or 2.  I am confused, however, by the "DIG" and "COMP" Input setting choices.  "DIG" seems to allow 1-5 plus F (which I assume to mean Front).  But there is no explanation as to how to assign Audio vs Video.  Furthermore, the manual (on-line as well) seems to think that the SR5001 has only 2 Comp inputs and 1 output when, in-fact, there are 3 inputs and 2 outputs.
Can you help?
  • JAMIE12 Mar 09, 2008
    No sound will come through receiver. It displays it is in 7.1 mode and I cannot change. Cannot change anything on surround modes.Tried to clear using method in manual will no change.
  • 787 Answers
5 Suggested Answers
likha
  • 790 Answers
SOURCE: No sound from TV
check the fuse output line in the speaker! or maybe you are in protect mode! checkout the speaker, maybe you have defective speaker, thats why your unit in protect mode, thats why no sounds coming out!
Posted on Oct 07, 2007
lynchms
  • 93 Answers
SOURCE: On the Marantz SR-18 amp
You have to assign the digital inputs on the setup menu from the remote control while you have the On screen display on a monitor or TV screen.
Posted on Feb 11, 2009
  • 163 Answers
SOURCE: Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Posted on Aug 15, 2009
mlapres
  • 757 Answers
SOURCE: component input no HDMI output
The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
Posted on Apr 15, 2010
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Aug 14, 2009 | Marantz SR5001
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Marantz SR5001 Logo
3,783 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
