Question about Toshiba Satellite A105 Notebook
Toshiba satellite laptop
My audio will only play from the internal speakers. When I plug in headphones the internal speakers keep going and I can hear nothing from the headphones.
  • 2 more comments
  • robertroberg Feb 15, 2008
    Hi Ginko,
    I was afraid it might be hardware too but a friend suggested I roll back the driver. I did that but it still wouldn't work so I updated the driver and that fixed it. I appreciate your input.
    Peace
    Robert
    Thanks it is fixed
  • robertroberg Nov 18, 2008
    Tom,
    God bless you I have been struggling with this for months and I followed your advice and fixed the problem
    Thanks
     mucho
    Robert Roberg
  • Anonymous Mar 25, 2014
    When playing any audio on my laptop I get a crackling noise from the speakers both internal & external
  • 3 Answers
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
Posted on Feb 15, 2008
Hey,
I recently had a problem very similar to yours (I'm currently running Vista on a new Toshiba L315 notebook). Anyway, after trying several different things to no avail I eventually found the exact number of my sound card driver details (control panel ---> device manager ----> sound, video and game controllers ----> double click the sound card ----> click driver tab). Mine happened to be driver 6.0.6000.16386, which I then googled (along with the name of my SC, high definition audio device) and found this software:
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Realtek-High-Definition-Audio-Codecs-R201-Vista.shtml
I downloaded it and installed it. After restarting as suggested sound played through the headphone jack and cut off the internal speakers. VERY HAPPY. I hope this helps.
Posted on Nov 18, 2008
  • Toshiba Master
  • 19,396 Answers
I do not think it is a software trouble Looks more like the jack connector in your laptop is broken. If the laptop is under guarantee get in touch with Toshiba, they will fix it. Otherwise contact your local computer repair shop and ask a quote. The part is rather cheap (no more than a couple of $ in US) but labour charge may be expensive as the laptop must be disassembled to do the job.
Hope it helps
Toshiba laptop Internal speakers loss of sound while playing games and watching videos .Sound first 10-15min then no sound.only way to get sound back by going into sound settings and disable speake
Could be an audio driver issue. Does the sound work okay if you plug in external speakers or headphones? If problem persists with headphones/external speaker
Boot into safe mode (F8 on windows restart)
Select Safe Mode
When windows loads (it will take longer than usual).
Control Panel > System Properties> Device Manager > Delete/ Uninstall your audio drivers, reboot your machine - audio should work now.
Apr 17, 2014 | Toshiba Computers & Internet
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
After trying to plug in headphones (in the headphone socket) I have lost all sound on my Toshiba satallite 2040 (Idid have sounds from built in speakers before hand) can you help
Hi
You have not mentioned which operating system you are using.
You might have changed the defaul audio settings.
Vista/Windows 7: Start > Cxontrol Panel > Sounds & Audio Devices > Hardware & Sound > Manage Audio Devices > highlight the external speakers from the list of devices > Set Default > Apply > OK > Restart computer.
Win XP: Start > Cxontrol Panel > Sounds Speech & Audio Devices > Hardware & Sound > Change the Speaker Settings > Advanced > Speaker Setup - select Internal Stereo Speakers > Apply > OK > Restart computer.
I hope this helps.
Aug 27, 2011 | Toshiba Satellite 2450-401 Notebook
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Not clear sound quality making some noise when i play a song
you need to uninstall and reinstall the audio driver or try to uninstall adn reinstall the player that you are using to hear sounds? is it doing the same if you are going to use a headphone? if so thats only a software problem, if headphone sounds fine, its the internal speakers thats having problem.
Sep 12, 2009 | Toshiba Satellite A205-S4607 Notebook PC
External speakers for toshiba laptop problem
Check device manager and make sure the audio drivers are not disabled. If so enabled it. I am quite sure you have checked to see if its muted. If it is enabled and its not working, try updating the drivers or uninstalling and reinstalling latest driver audio driver OEM site.
**If you reinstall the same driver you might get the same error but its what a shot.**
May 22, 2009 | Toshiba Satellite A75-S211 Notebook
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Toshiba audio failure
Check for any hardware conflicts. If there are none then the 3.5mm stereo jack for audio out may be damaged - it has internal switches to turn off the speakers when headphones are used.
Mar 16, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite A105 Notebook Logo
297 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
